I've read somewhere that the turbo on the van version of the psd has a larger outlet port than what is used on the truck version. has anybody else heard that or can verify it's truth?
Would the turbos be interchangeable?
Thanks,
Marvin
I believe, though not positive, that there was a difference in turbos in the F Series and E Series with the 7.3L. I believe that the F Series had a Waste Gate and the E Series did not as well as some other smaller differences. The 6.0L is the same in both applications, just different power ratings. Chris
Squatch,
would there be an advantage to putting the e-series turbo on an f-series psd?
would that increase airflow?
Is the e-series turbo outlet actually 4" and bigger than the f-series?
thank you for the information. Are you a psd mechanic? sounds like it.
i believe he is also thinking about the 7.3. referring to wastegated to non wastegated. and the 6.0's are the same. no difference in turbo.
