A Couple Of Customers With A 06-07 Duramax'' Have Been To The Dealership With Intermitent "cackling" "rattling" Noises,, With Fuel Code Concerns.. The Dealership Removed The Box,, Problem Solved.. Plus ,, They Are Interested In The Evolution Box To Eliminate The Speed "warden".. 96 Mph As I Understand.. I Need To Call Edge And See What's Up. Any Info From The Inside??? Thanks,, Frank -d-tank..
F
I am confused, so they took the box off, and now you don't have the problems?
Who in their right mind leaves a tuner box on the truck when they take the truck into the dealer? You are just asking for a warranty denial if you do that.
Could be the Edge tunes have excessive timing....that could cause those sounds.
These Guy's Go To Lunch With The Service Manager At The Dealership.. He Knows They Have Chips.. He Likes Chips,, But The Techs Fix The Trucks.. Ase Master Certified ,, L1 Certified,, Gm Certified, Duramax Specialist, Factory Trained.... The Additude Has Two Times,, Set This Problem,, {so They Say } Guys And Gals Like The Evolution Alot Better, No Speed Limiter.. What Do I Tell Our Customers?? Input Appreciated
F
I guess you give the customer what they want. If they don't want the "rattle", and the Edge gives them that, then they are going to have to go with something else.
