This is a used Edge Comp Box (HOT) for a 1998.5 - 2000 Dodge Ram Cummins Diesel. It is for the 24 valve trucks. It was used on a truck for about a year and then the truck was sold so the box is no longer needed. This is the HOT box therefore it has 6 levels of power instead of your normal 5. This is a more powerful box than the Edge Juice with Attitude. It should work on 2001 and 2002 trucks with an attachment but you need to check with Edge to make sure. Don't but a brand new box for $650 when you can buy this perfectly fine used box for half the price! The box is sold AS-IS with no warranty offered by me. Edge stands behind their products throughout its life. If you have any questions please ask!
$450 shipped!
This is from Edge:
The Edge Comp module maximizes engine efficiency by monitoring the RPM, timing, turbo boost pressure and fueling parameters of your Cummins engine. The Comp module uses this information to determine and control both fueling and timing enhancements for the Bosch fuel injection pump. Timing and fueling enhancements are controlled via CAN-BUS through the Data Link and by connecting directly into the Bosch fuel injection pump.
The Edge Comp features five power levels with power gains from 40-120 horsepower. Each of the levels has five independent adjustable sub-levels to control low boost fueling, providing a total of 25 levels of adjustability! The responsiveness settings enable you to dial-in the optimum balance between responsiveness and low boost smoke control no matter what additional power modifications have been made to the engine. The Comp module is fully adjustable on-the-fly and mounts inside the cab.
The following power gains are representative of an actual test vehicle. These gains were measured on a SuperFlow Dyno at an altitude of 4400 ft above sea level, and represent power delivered to the rear wheels of the test truck. The only modification made to the test truck was the addition of the Edge Juice module. Power gains may vary based on vehicle and geographical location.
Level 0: Stock
Level 1: 40 Horsepower - 150 Foot Pounds of Torque
Level 2: 60 Horsepower - 200 Foot Pounds of Torque
Level 3: 80 Horsepower - 250 Foot Pounds of Torque
Level 4: 100 Horsepower - 300 Foot Pounds of Torque
Level 5: 120 Horsepower - 350 Foot Pounds of Torque
Level 6: HOT (this is an extra level that is purchased through Edge)
I also have it listed on eBay here:
http://cgi.ebay.com/ebaymotors/Edge-Comp-Box-HOT-Dodge-Ram-Cummins-Diesel-1998-2000-/160600406266?pt=Motors_Car_Truck_Parts_Accessories&hash=item256487b8fa
