OBS
What all does this have? Custom tunes, Gauges (which ones)
Chip or programmer
The EVO II is a programmer, but it does have gauges. It looks similar to the Attitude monitor. I believe that DP-Tuner is the sole vendor for custom tunes on the EVO II. If you don't want a chip this is a good option and I'm a big fan of DP-Tuner's programming compared to others I've had.
OBS
What all gauges does it come with? Is it as good as a F5
The new Evo is a very nice unit. The monitor is sleak. Their are 11 different pids that you can monitor. EGT(with a supplied probe),trans temp,boost, EOT are just a few to name that you can monitor.
It will depend on what you have plans for with your truck as to which one to get and your prefferences as to if switch on the fly is an important feature to you.
Diane
On edit- this unit is only for the 99-03 sd's.
