i just installed a edge juice with monitor on me 98.5 and im not getting any boost pressure reading. everything else is working great. i have the juice set on the right year of truck and made sure all the connections where tight. i see the boost on the monitor but i says 0 all the time. i did search all night on three forums and got nothing. any help please thanks. where should i look?
michael
yeah...thats what i was going to do 1st of the week..im just fishing for ideas
its cuz edge is junk lol
jk lol
I had that same problem. The edge harness was bad at the map sensor connections, but mine threw boost faults and started de-fueling. They sent me a new harness no questions asked after I told them everything I found.
is your data link together correctly? my data link to the front left of the block (from sitting in the driver's seat) had a plug in the end and would therefore not make a complete connection
oh and i saw ur sig....if you are runing a stock housing...youi shouldnt be seeing 40psi. i mean you COULD, but only 35psi are usable on the stock setup. after 35 it just blows hot air.
