The EGR coolers on the 6.4 has been moved to the frt and left outside of block. My question is, did they also move the oil cooler or did they make an EGR delete that could be used in our 6.0. :popcorn:
********* and Mafia #90
this is a new one for me.
I looked at a 6.4 the other night, and the intake configuration along with everything else was different. I doubt you would find many interchangeable parts....if any.
cb44473 said:
the oil cooler is in the same spot its the same block basically.
Since you work on them, what do you think. Could a person make it work or is the intake completely different. My wife and I drove past Douglas today(tue), man was it windy. Staying in casper tonight and then heading for Billings, Mont. :popcorn:
should have stopped in. the intake is completly different the only thing that is the same is the block just a bigger bore and change in stroke. I guess since the bottom end of the 6.o was pretty much bullet proof ford and international decided to use it again. and the oil cooler gets coolant from the block instead of the front cover so it wouldnt work either. had to look that one up.
the 6.4 has two egr coolers if i rember correct from class on those...
