1 - 16 of 16 Posts
I have a 1999 7.3 diesel that was bought used about 3 years ago for a tow vehicle. Love the truck, just not the problems that have been occuring.
I have replaced batteries and alternator because batteries were dying. If the truck sits for several days without running batteries are dead.
Because the truck was bought used I figure I should tell you that there is a aftermarket stereo and alarm with auto start. Not sure at this time what brand alarm.
Some of the things that have been happening and I don't know if any of this is related because I am not a mechaninc. I will list them. Back light in truck bed turns on mysteriously, wet weather makes radio turn on, fan has been found running in the truck when key was out of the ignition. Interior lights will not work when any door opened but will turn on when switched on manually.
I also aquired some kind of leak that during a heavy rain seems to drip right by the drivers side E brake pedal.( I am pretty sure that's not good) it is where the PCM is if I recall. I am working on that as we think.
Started the truck this morning to make sure the batteries were ok and ran for 10-15 minutes. Put my multimeter on it and the alternator was putting out somewhere around 14.26v turned the truck off to see where the batteries where and they were at 12.86... Then watches the volts conitue to drop like I was watching the second hand on a clock 12.86...12.72...12.55... Is this normal? Again I admit I am no mechanic.
I know I am about to go on a wild goose chase but hope that someone can point me in the right direction maybe give me a clue.
Since I can not buy the person who help a beer this is what I will do. The person that point me in the right direction to fix this problem will get a $25.00 AMEX gift card in the mail. I am serious!!!! You can go get your own beer. Multiple input may actually get multiple gift cards.
I really appreciate any help that you can give me.
Paul
Oh yeah, The horn stopped working last week... Go figure?
Well, I am no electrical wiz, so I probably won't be in the running for the $25 AMEX card ... but ... here are my suggestions based upon my experience.
First I would remove the stereo and alarm. Who knows how they put it in or wired it. I have seen lots of issues with home installs of this type equipment. I had a Jeep YJ where the stereo would go off if you turned on the headlights.
Second, it sounds like you have a short or intermittent connection. Maybe some rust in a connection. Definitely need to fix the water leak. If your 99 is like my 02 the area you describe is also the area your fuse panel is located. Check for water damage / rust in your fuse box.
Just a start, I’m sure there will be some more experienced answers shortly!
Good Luck :happymugs
member
No need for the gift card but thanks for the gesture..:happymugs
I personally would start with the terminal connections and fuses. IMO
All hots and grounds, battery, alt to the fuse blocks.may seem a little much..Noted that the batts and alternator was changed, and the water leak is right by the fuse block in the cab, that's were I'd start..
If all seems to be ok there, I'd jump right into chasing down the stereo and alarm wiring.
since it's affecting the lights and horn.
When the wiring for those items are found you'll be testing for constant draw or open circuit on the main power and memory wire..Any amps installed for the stereo?As far as seeing the drop involtage after shutting down, the drop should stop after the computer, relays and interior lights go off..The alarm shouldn't be drawing that much..
Hope that gets you started in the right direction.. I'm sure others have some more thoughts, advice and will help you out on here that's gone through the problems you're experiencing now..Good luck and keep us updated
It sounds as though your windshield has developed a leak.
My guess is your GEM module is going. If that's the case, the truck just won't start one day when you get in it. Mine left me stranded @ the NAPA store :damnit
Get the windshield pulled and the weatherstripping replaced. That should cure the water leak.
Then start tracing down the gremlins, if they still exist.
prt
IMO, CRAWFISH is dead on...you've got an open circuit somewhere that is drawing amperage. Electrical issues are hands down the most evil of evil problems that you can face!
My '99 7.3L also had an aftermarket alarm/remote start installed and one day my neighbor came into my house and asked if I knew my truck was running...:eek: WTF??? Just mysteriously started up! Needless to say, had it removed and no issues since, although mine wasn't "leaking" amps anywhere, thank goodness. :woohoo (your alarm wouldn't happen to be an AUTOPAGE brand, would it?)
You're going to need schematics, a multimeter, and tons of patience to find your problem. Good luck and DEF let us know what you end up with!
:salute
Thanks to everyone that has replied so far.
I already called to have the windshield pulled and replaced. I will continue to report my findings as I go along.
GEM Module... How much will that set me back?
I was also told to check the ground on the passenger side of the engine block. At this point I can't rule anything out.
Think I am going to pull the radio completely and wire it new myself. The prior owner was younger and I know when I was young, quality work was not my strong point.
Keep the ideas coming gentlemen and the beers are on me when I get this resolved:happymugs
GEM module ain't cheap - between $2-300 iirc, but it's been nearly 5 years since mine went out. Check out
It's a PITA to get to, though. I spent the better part of 2 hrs getting the old one out and the new one in (start to finish, no beer - stuck in the NAPA parking lot).
Fuller Ford Parts is a TDG vendor and should be able to get you the best price. Give them a call and tell them you found them @ TDG.
Keep us posted.
prt
hey redtruck the link say's it's broken..?
:salute
I wtih them..
More Information...
Windshield is being replaced so that shoudl take care of the water problem.
Had rain here last night and there was water by the E brake again. I started the truck to charge the batteries and all was fine. It started sluggish, probably because of the drain on the batteries.
Turned the truck off after 15 minutes and heard one of the relays clicking like crazy. It was the Accessory delay relay.
Could this be tied into the problem??? I heard somewhere that one of the symptoms was interior light problems. I have those also.
Interior lights on the truck will only go on when you hit the swich at the actual light in the truck. They will not go on when any doors open or when you turn the switch on the dash. Does this mean anything?
I thinnk the accessory delay relay is about $40.00 does it pay just to replace or am I just wishing for the best.
Still working on it.
Paul
member
Morning Mr. Paul,
New info to go on.cool. So Just a thought,,,
I would pull the switch in the dash and check power in and out of it as well..
You could change the relay, but I'm not 100% sure that's the problem.
But checking the switch and changing the relay would rule them out as the open circuit or constant draw... Keep us updated sir..Good luck
Symptoms
1. Water infiltration.
2. Clicking relays.
3. Interior light problems.
I'm telling you it's sounding more & more like the GEM module to me.
Get it dried out good for starters and see if the problems clear up. If not, I would start with the lower cost items (relays) before spending the $$ on the GEM but I still think that's where you'll end up.
prt
Discussion Starter #14
I have the same feeling about the GEM. Does anybody know if the GEM is flug and play or does it have to be reprogrammed after intalling form a Ford dealer?
They just kill me with the prices they charge for this stuff.
Paul
Mine was pre-programmed when I bought it, but I gave them the part # off my old one. They were able to reference it with an updated part #.
I think I also had to tell them what options I had (power windows, door locks, etc.) Make certain you ask the salesperson.
BTW, the Fuller Ford Parts folks just saved me a bundle on some parts compared to my local dealer. I'm all about buying local, but our local dealer is notorious for gouging customers. Fuller Ford Parts took great care of me.
prt
Discussion Starter #16
My local dealer charges about twice the amount for the same parts. He's not making that money on me.
1 - 16 of 16 Posts
