The cummins has ALOT of power it is running top notch but here are vitals that jump out at me, from a dead stop with normal throttle to accelerate 1/4-1/2 egts are 650-750, boost 19-22 psi(seems high) and it moves almost to good and there is 0 smoke out the tail pipe but the down side is it seems like it is using more fuel than it should, if you guys can share what you are seeing that would help out.... :usflag Happy Veterans day
and just to be clear this is the stock charger, stock injector, and i only have a quadzilla max mileage module, i will install a vgt off a 2009 using fleeces controller after my broken ribs heal
