Vendor
If you're looking for new Silverado/Sierra side steps, then new 6.5" Wheel-to-Wheel Black Wrinkle Powder Coat Running Boards by Hammerhead may be the right choice for you! Being made from high grade 1.75" steel tubing, they are finished in a 2 stage black powder-coat that will hold up to the harshest conditions.
These running boards feature a broad stepping surface that will make it easier for you to get in the cab or reach your cargo in the bed. Each running board platform can hold up to 300 pounds of weight. They are installed securely to the body of your truck using the OEM mounting. Check the new Hammerhead Running Boards at CARiD!
Hammerhead® - 6.5" Wheel-to-Wheel Black Running Boards
Features:
  • Mounted securely to the cab or the body mounts depending on application
  • Have platforms per side allowing access to each door, as well as access to the bed
  • Each running board platform has the ability to hold up to 300 pounds (a combined 600 pounds total weight)
  • Mounting brackets included
View the full list of Hammerhead Products at CARiD: Hammerhead™ | Bumpers, Bull Bars, Running Boards, Accessories — CARiD.com
