Hey guys. New to this great forum. I'm looking at a 03 Excursion with the 6.0. I got the guys on the oasis board to run a report and I am posting it in this message. I need help with what you more knowledgeable guys think about it. Odd that there is no records but 2008 and 2009. I know the 6.0 had problems. I don't want to buy something that stays in the shop. Thank you.
Standard Claims List For Model Year 2003
1FMNU44P03ED68092 T/L1 F T/WD T/BD T/B A1 T/BE T/YB 04-JUN-2003 30-AUG-2003 123148 USA 54 * * * * * * * 82355
AWS Claim Key: 15788421 Trx Code: 06E17 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 06475 - * Name: GATEWAY FORD INC Ph: 985-3867790 St:LA Ctry Cd: USA Reg Cd: NA Repr Date:23-JAN-2008 Doc #:60336205
Cust Comments: 06E17
Tech Comments: PERFORMED 06E17 AS PER RECALL
AWS Claim Key: 15788422 Trx Code: 59B01 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 06475 - * Name: GATEWAY FORD INC Ph: 985-3867790 St:LA Ctry Cd: USA Reg Cd: NA Repr Date:23-JAN-2008 Doc #:60336206
Cust Comments: 59B01
Tech Comments: PERFORM TEST DRIVE
1FMNU44P03ED68092 T/L1 F T/WD T/BD T/B A1 T/BE T/YB 04-JUN-2003 30-AUG-2003 123148 USA 54 2E03 030402 3C3Z 9E527 EBRM D42 42 82355
AWS Claim Key: 15788420 Trx Code: E72 Labor Hrs: 5.9
Dlr Cd-Sub Cd: 06475 - * Name: GATEWAY FORD INC Ph: 985-3867790 St:LA Ctry Cd: USA Reg Cd: NA Repr Date:23-JAN-2008 Doc #:60336204
Cust Comments: CK ENGINE MISS WHEN STARTED COLD
Tech Comments: PERFORMED POWER BALANCE FOUND 2 AND 4 INJECTORS DROPPING OUT ON COLD START. ALSO ICP AND HARNESS LEAKING AND LOW VOLTAGE REPLACED INJECTORS 2 AND 4, REPLACED ICP ANC HARNESS
1FMNU44P03ED68092 T/L1 F T/WD T/BD T/B A1 T/BE T/YB 04-JUN-2003 30-AUG-2003 123148 USA 54 1H03 030008 5C3Z 9F452 AA E29 55 82355
AWS Claim Key: 15793661 Trx Code: E72 Labor Hrs: 1.2
Dlr Cd-Sub Cd: 06475 - * Name: GATEWAY FORD INC Ph: 985-3867790 St:LA Ctry Cd: USA Reg Cd: NA Repr Date:23-JAN-2008 Doc #:60336201
Cust Comments: EXCESS SMOKE FROM EXHAUST ALSO CK ENGINE LITE ON
Tech Comments: REPLACED EGR VALVE AS PER TSB 07 21 09
1FMNU44P03ED68092 T/L1 F T/WD T/BD T/B A1 T/BE T/YB 04-JUN-2003 30-AUG-2003 123148 USA 54 2H01 030008 3C3Z 6K854 DA E42 01 82355
AWS Claim Key: 15788419 Trx Code: E72 Labor Hrs: 3.7
Dlr Cd-Sub Cd: 06475 - * Name: GATEWAY FORD INC Ph: 985-3867790 St:LA Ctry Cd: USA Reg Cd: NA Repr Date:23-JAN-2008 Doc #:60336202
Cust Comments: CK EXHAUST FUMES IN CAB
Tech Comments: SMOKE TEST FOUND LEAKING TURBO Y PIPE R&I TURBO REPLACED Y PIPE
1FMNU44P03ED68092 T/L1 F T/WD T/BD T/B A1 T/BE T/YB 04-JUN-2003 30-AUG-2003 123148 USA 72 1B03 030204 3C3Z 6A642 CA L87 42 100750
AWS Claim Key: 16432554 Trx Code: 0968D Labor Hrs: 9.2
Dlr Cd-Sub Cd: 08211 - * Name: ROBINSON BROTHERS FORD Ph: 225-2938900 St:LA Ctry Cd: USA Reg Cd: NA Repr Date:08-JUL-2009 Doc #:05376001
Cust Comments: COOLANT LOSS POWER LOSS SMOKE FROM EXHAUST
Tech Comments: APPROVAL # E57LN PERFORMED TSB 090803A IN LINE PRESSURE TESTED CAP FOUND THAT CAP WAS GOOD,VACUUM TESTED EGR COOLER FOUND THAT VACUUM DIDN HOLD FOR MORE THAN 7 MINS,PERFORMED TSB 090803B TESTED EGR COOLER OFF THE TRUCK FOUND THAT IT WAS LEAKING WITH 30 PSI SHOP AIR HOOKED TO IT,REPLACED EGR COOLER AND INSTALL ED UPDATED OIL COOLER KIT,PERFORMED TSB 090803F CHANGED OIL
