Banned
Pros or cons to using it? Does it stress anything out? Should I not use it in certain situations? When should I use it?
I'm not familiar with these... Any info is appreciated..
You can use the exhaust brake in every situation you want it will not hurt anything.
Reactions: Jeremiah
Using the EB also helps reduce the chances of the vanes in the variable geometry turbo from sticking. Keeps soot from building on the vanes.
Banned
wow really?!?
Start truck turn on exhaust brake. Every time is what I do.
Reactions: Jeremiah
Banned
Hey do you have a "Tow/Haul" button next to your EB button?
Yep ! I only use it when i have a real heavy trailer and usally just on take off it seems to be to aggressive on stopping. I usally just use the rocker switch on the shifter for stopping. But you will probably never have to change the brakes.
Reactions: Jeremiah
Built Not Bought
I actually just changed my brakes at a 168k mi and they still had 1/4 or better. Right rear was wearing funny on the ends and starting to make some noise lol. I went with a set of thermo quite pads from Oreilly lifetime warranty $100.00 for front and rears
Reactions: HLC2239CUMMINS
