1 - 17 of 17 Posts
has anyone ever heard of a 7 inch exhaust from the transfer case back?? what do you guys think that would to??? im planning on ether a 6 inch or 7 inch not sure yet?? opions?
Ryan
7" that seems like it would echo down the pipe to much? i would think that it would sound like straightpipe underwater. but im sure you could put any size on........by the way, nice truck
what's the point? it seems like more work and more money for no gain... but i am curious what will a 7 inch exhaust do for the performance? i don't think anything....
I think it will drone really bad and cost a lot to get fabbed up/bent. I'd won't have any affect on performance with a normal sized DP
:2cents
Diesel Mafia #67
I wouldnt go any bigger then 5inch piping..
Discussion Starter · #6 ·
alright thanks guys, idk i thought it would be different but the price is way more then i want to spend. do you guys think 5 inch is big enough or should i do 6 inch?
formally dodge97ctd-sc member #12
had 5 on my dodge...didnt sound too much different from 4....lil deeper roar but wasnt as loud
What size is your downpipe?
5" is more than enough. If you do the math the area inside a 5" pipe is 56.25% larger than a 4" pipe. And 6" has more than double the area of a 4"
Discussion Starter · #9 ·
ya true, its a 4 inch DP soon to be 5 inch though. im just thinking sound, what do you guys think it would sound like with 6 inch??
I'd be afraid of a bad drone, heck at that size it could be considered an echo LOL
Diesel Mafia #67
Bigger the DP... quieter the truck is... if you go too big you could also hurt ur performance... I going 5in DP straight back to the tail pipe..
Discussion Starter · #12 ·
ya i might do 5 inch now, 6 and 7 are way to expensive and i want to be able to put a muffler on it if i had to
gone fishin!
they used 6 an 7 inch exhaust systems on old fishing boats and trawlers with the 5.9 cummins in it, they droned so bad you almost wanted to jump over the side. i cant imagine how you could stand 5 inch let alone 7 inch.
hey just curious, you wouldnt happen to have a dp for a 99 24 valve bigger then a 3 1/2 inch would ya? because right now my egt's without the box being on are running about 1500 degrees which isnt good, so im needing a bigger down pipe hoping to cool it down... when i turn my box on i can peg the 1600 degree gauge with now problem. thanks
:whs on the turbo. Other thing you could do is a 5" system, then take your stack and adapto it to a really long 7" tip (to the axle or thereabouts) so people behind you or someone just taking a casual glance would think it's a 7" exhaust. But once again on the drone/echo issue...........
Discussion Starter · #17 ·
i dont have any drone with the stack setup, its all 5 inch underneath to. im not sure i might keep the stack for awile. i messed my truck up last night, so the exhaust can wait.
1 - 17 of 17 Posts
