I just picked up a 2004 F250 4x4 crew cab and would like to swap out the wheels for something a little newer/modern. There are a lot of wheels out there that came off of newer King Ranches and Harley Davidson models for sale. My question is whether or not wheels from an '08 will fit on an '04? Thanks! I'm new to Ford and new to diesel, so this may be a learning experience! Yes, it has the 6.0...Yes I know the horror stories...Yes I got an extended warranty from Ford! It's a 1 owner, no mods, EGR cooler and FICM replaced. No head work yet........Absolutely love it so far!
I beieve that the 08`s will fit the 04, but the 04`s will not fit the 08 due to increase size in brake components.
Doug
no the off set is different the wheels will fit but rub really bad but you can use wheel spacers to fix the off set ,the 08 is a wider track with then the 04 ,or easy thinker the leaf truck is skinner then the coil spring trucks ..
