21 - 24 of 24 Posts
· Registered
TxC seams to be blowing a bunch of smoke about his fan controller. First it's is controlled off coolant temps now it's not...
· BUG JUICER and
Discussion Starter · #22 ·
cooksvillewildc said:
On a different note, for simplicity, could one add a thick piece of rubber to the current fan pully to increase its' diameter to decrease fan speed somewhat - not sure what the difference in diameter is between the LB7 fan pully and our LLY one?
:Thumbup:
· Registered
The press fit collar out of some type of metal is probably the best choice. Aluminum would be nice to save weight, but as 4hweelin' noted there are wear problems. A powder coating or even a layer or two of bed liner might do the trick. Line-X claims to be able to spray up to 1/4".
· Registered
21 - 24 of 24 Posts
