I developed a great CAI, and it reduces max IAT from 220 to 150 when towing. The fan (for those of you who still live with it) is the cause of the 160. This heatup is responsible for a great deal of our cooling system shortage.
the simplified overheat mechanism.The IAT rises with fan engagement, hence the turbo outputs hotter faster charge, hence the CAC becomes hotter, hence keeping the fan on, never letting it shut off:
I want max IAT reduced to ambient plus 20. That takes the induction system out of the dead end thermal spiral.
So the idea is to provide a pressurized source of ambient air to displace the fan air that is migrating into the fender.
A multlouvered scoop that surface mounts for aesthetics, to be painted the vehicle color or carbon fiber. I hope that 600 SCFM at 60 mph, and 2 inches water column ram pressure will suffice. The louvers will direct any water to the area behind the intake, so element loading will bo a non-issue
