Picked up a 95 FL70 with a 8.3 cummins, 275 HP and 10 speed trans, 32,000gvw. Runs good. Only problem is sometimes when starting it it fires right up but as soon as you let go of the ign key it will die. When it does this I find that by giving it some throttle while starting and holding the ignition key in the start position for a fraction of a second after it starts it then stays running.
I am thinking it is a electrical problem between the switch and a fuel solonoid and possibly losing electrical current to solonoid when the key is going from start to run position (maybe a relay switch?)?
Any thoughts, suggestions or trouble shooting ideas would be appreciated.
