Alaskan Assassin
My 2001 4x4 has started flashing the ABS and E-Brake lights simultaniously while driving. they stay on anywhere from 1-20 seconds and then stay off for the same durations. I checked for P codes and got none. If anybody has any suggestions I would be most grateful.
2nd Gen Guru
Check for loose wires, broken wires, bad ground connections, etc... Also check fuses too... A fuse might of broke and is making contact now and then...
My experience was a fuse got loose under the hood and was making contact now and then... When it would disconnect is would trip the BRAKE and ABS lights... Push the fuse back in its socket and problem gone...
Alaskan Assassin
shoulda thunka that
Alaskan Assassin
:thanks: Thanks Bro, I swear I've learned more about my truck and what it's capable of in the last couple of months just by reading your responses to others questions. Your personal site kicks *** too. I am now a 2 stroke oil believer and am trying to convince my buds too. (IT JUST MAKES SENSE!) This site rocks because of people like you. THANKS AGAIN!!!
