1 - 11 of 11 Posts
Anybody have any flatbed plans or know where to get some? I need to put a flatbed on my 4900 and need ideas. I need to put a gooseneck ball so I can pull a horse trailer is about the only criteria that I have for it.
'Ol Builder guy
I take it you are capable of fabricating it yourself?
The reason I ask is there are so many companies that make nice gooseneck/flatbed combinations-might be cheaper in the long run.
Hopefully you can go aluminum or stainless?
I probably could do it myself.... but I would rather leave it to the pros. I just want to see some different plans so I can see what I like, how far braces and stuff like that should be apart, and what gauges of steel should be used. I think I'm just going to have a plain steel bed made...... I don't have a bunch of extra $$$$ because of the trailer I'm going to get. I found a shop that seems to do pretty good work that said they could do a 11ft custom bed with 2 48" tool boxes a gn ball and a 200 gallon water tank for around $3500.
I'll probably pick up a truck trader or something like that and see what I can find in it that will work and compare prices for a while before I do anything.
'Ol Builder guy
$3500 for all that sounds like a smokin deal. Is that installed, or just to build the body?
Installed..... I'll probably need to get the water tank myself and have them put it on but it's basically bolting it down. The tanks were in the $150-$250 range depending on the size I want (plastic tank).
Do a search for hauler beds, some are close to the price you're getting to build one and they are some heavy duty beds (Western Hauler Style).
I am in the process of making one for a Freightliner FL70 as we speak and I just bought and old steel bed for a normal pickup and went to work on it.
I am having to widen it about 10in and put new side skirts on it as well as make a trough for the gooseneck ball. So far it going good, and I shouldn't have much more than $300 ties up when I'm done.
General Contractor
That is similar to what I am planing to do. I am going to fabricate the bed my self but it will be a flat bed dump with a small removable plate that will hide a goose neck ball below the bed. I try to make all my tools the most versatile possible.
In the passing lane
Check out B&W's site.
do you have drawings for the lift hinge or are you using an old one. I could use a set of drawing if you have them.
what does not kill you ..
I am also looking to make a bed. I think I can build what I want rather than settle for a pre built bed. I am sure that there are many great beds out there but I am convinced (it may be a mental problem) that I can do better.
I would like some drawings or plans which of course I will modify for my own needs
wftree
General Contractor
I have some sets I cut off some old dump trucks. I will look to see if I can find a set of drawings for a good strong hinge design...
1 - 11 of 11 Posts
