Ok need help, got a 3ZJ manual pump 3406 cat. When I first bought Truck (Oct 2017) it would pull about 15 # manifold pressure and no smoke. After driving around 30 days, one day while coming home empty it all of a sudden started pulling 21-22# and trailing a little smoke. Had more power of course so I continued to watch the pyro and nothing over 750 so I continued driving it that way. Skip ahead to last week(Feb 2018), loaded headed west it all of sudden reverted back to only pulling 15# mp and trailing smoke stopped and felt gutless. Came home changed filters replaced transfer pump, checked fuel pressure (45-50+). AFRV plunger was removed to eliminate that, still doing same thing. Can start off leaving driveway and drive 5+ Miles and it’s 21-22# then all of sudden while still pushing accelerator it falls off to 15# and seems to flatline. It has blew my mind why it would go back and forth doing this. Any tips???
Hmm. It's like it happens when it hits operating temp.
If you shut it down for a short while (not long enough to cool) what happens?
Yes it seems like when it gets to the operating Temp I notice it also if I stop at a stop sign or get fuel At first it pulls good with high manifold pressure but as soon as I get Rolling good it governors back down
Well, if you have taken afr diaphragm out of the equation then ck timing advance and possibly governor flyweights are hanging up. I am assuming you do not have a gated turbo. Governor flyweights can do some strange things before they completely disembark. Ask me how I know. Also, check air charge cooling system when it is low and someone that knows more about air dryers than I do might be able to help you also.
Interesting on the governor ⬆
That would explain things.
