Hi,
Does anyone have any technical specifications as to the Ford-New Holland 6.6L and 7.8L in-line six-cylinder turbocharged diesel engines that were produced from 1985 to 1993?
Off the top of my head, the 6.6L was used in the following applications:
F-600 Diesel
F-700 Diesel
B-700 Diesel
CF-6000
CF-7000
From a 1985 Cargo brochure, it lists the 6.6L as having a square bore and stroke of 4.4" for a displacement of 401 cu. in. The peak hp of it is 165 @ 2600 rpm and the peak torque is 388 lb/ft @ 1600 rpm. I know there are other ratings out there for this (and the 7.8L) as well.
And the 7.8L was used in these applications:
B-7000
LN-7000
CF-7000
F-8000
L-8000
LN-8000
LT-8000
LNT-8000
CF-8000
CFT-8000
LTS-8000
If anyone here can please clarify the technical specs for these two diesels, I would appreciate it.
Thank you,
Ben (Gillig8V71)
F-600 Diesel
F-700 Diesel
B-700 Diesel
CF-6000
CF-7000
B-7000
LN-7000
CF-7000
F-8000
L-8000
LN-8000
LT-8000
LNT-8000
CF-8000
CFT-8000
LTS-8000
Thank you,
Ben (Gillig8V71)
