Sorry for asking for two, but we have been looking hot and heavy at these two trucks:
1FTSW21R08EC95048
and
1FTSW21R68EB04152
Standard Claims List For Model Year 2008
1FTSW21R08EC95048 T/F7 F T/BC T/BD T/E A1 T/BE T/QL 10-DEC-2007 08-APR-2008 147023 USA 0 1F01 030301 8C3Z 8009 B L87 D8 17
AWS Claim Key: 657253 Trx Code: 2 Labor Hrs: 2.7
Dlr Cd-Sub Cd: 03930 - * Name: BURD FORD, INC. Ph: 317-5458551 St:IN Ctry Cd: USA Reg Cd: NA Repr Date:02-APR-2008 Doc #:16714001
Cust Comments: CUSTOMER STATES, THERE IS A FLUID LEAK FROM ENGINE AREA
Tech Comments: INSPECTED ENGINE COOLING SYSTEM AND FOUND THE FOLLOWING: PERFORMED COOLING PRESSURE TEST, REPLACED LEAKING RADITOR, RETESTED ALL O.K.
1FTSW21R08EC95048 T/F7 F T/BC T/BD T/E A1 T/BE T/QL 10-DEC-2007 08-APR-2008 147023 USA 8 1F01 * * * * * * 16774
AWS Claim Key: 1989140 Trx Code: 08B06 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 04716 - * Name: DON HINDS FORD INC Ph: 317-8499000 St:IN Ctry Cd: USA Reg Cd: NA Repr Date:13-NOV-2008 Doc #:141543D
Cust Comments: N99 08B06 COOLING SYSTEM TEE
Tech Comments: 16774 INSTALLED COOLING SYSTEM T PER 08B06
1FTSW21R08EC95048 T/F7 F T/BC T/BD T/E A1 T/BE T/QL 10-DEC-2007 08-APR-2008 147023 USA 8 2E02 * * * * * * 16774
AWS Claim Key: 1989141 Trx Code: 08C04 Labor Hrs: 0.9
Dlr Cd-Sub Cd: 04716 - * Name: DON HINDS FORD INC Ph: 317-8499000 St:IN Ctry Cd: USA Reg Cd: NA Repr Date:13-NOV-2008 Doc #:141543G
Cust Comments: N99 08C04 FUEL STOPPER BRACKET
Tech Comments: 16774 COMPLETED RECALL 08C04, FUEL TANK STOPPER BRACKET
1FTSW21R08EC95048 T/F7 F T/BC T/BD T/E A1 T/BE T/QL 10-DEC-2007 08-APR-2008 147023 USA 8 1F01 030301 8C3Z 8009 B L87 D8 16774
AWS Claim Key: 1989139 Trx Code: E84 Labor Hrs: 2.7
Dlr Cd-Sub Cd: 04716 - * Name: DON HINDS FORD INC Ph: 317-8499000 St:IN Ctry Cd: USA Reg Cd: NA Repr Date:13-NOV-2008 Doc #:141543C
Cust Comments: L87 COOLANT LEAKS AT LEFT LOWER CORNER OF RADIATOR
Tech Comments: 16774 VERIFY CONCERN DIESEL COOLING SYSTEM DIAG. PRESSURE TESTED AND INSPECTED AND FOUND THAT COOLANT IS LEAKING FROM RADIATOR ,REPLACED RADIATOR AND TOPPED OFF COOLANT AND ROAD TESTED VERIFY REPAIRS
1FTSW21R08EC95048 T/F7 F T/BC T/BD T/E A1 T/BE T/QL 10-DEC-2007 08-APR-2008 147023 USA 21 1F03 030304 AC3Z 8260 A L87 42 30545
AWS Claim Key: 4881850 Trx Code: E84 Labor Hrs: 0.9
Dlr Cd-Sub Cd: 02246 - * Name: BOB CHAPMAN FORD, INC. Ph: 937-6420015 St:OH Ctry Cd: USA Reg Cd: NA Repr Date:02-DEC-2009 Doc #:09997402
Cust Comments: CUSTOMER STATES NO HEAT UNLESS VEHICLE UNDER HEAVY ACCELERATION AND SMALL COOLANT LEAK.
Tech Comments: CHECKED OUT UNIT FINDING UPPER RADIATOR HOSE HAD FAILED. REPLACED UPPER RADIATOR HOSE AND TOPPED OFF FLUIDS.
1FTSW21R08EC95048 T/F7 F T/BC T/BD T/E A1 T/BE T/QL 10-DEC-2007 08-APR-2008 147023 USA 21 6R01 011001 8C3Z 26611B60 BB S40 42 31458
AWS Claim Key: 5006742 Trx Code: E84 Labor Hrs: 0.5
Dlr Cd-Sub Cd: 02246 - * Name: BOB CHAPMAN FORD, INC. Ph: 937-6420015 St:OH Ctry Cd: USA Reg Cd: NA Repr Date:21-DEC-2009 Doc #:10026001
Cust Comments: CUSTOMER STATES FRONT MIDDLE PASSNEGER SEALT BELT IS BROKEN.
Tech Comments: REPLACED CENTER FRONT SEAT BELT.
1FTSW21R08EC95048 T/F7 F T/BC T/BD T/E A1 T/BE T/QL 10-DEC-2007 08-APR-2008 147023 USA 25 1F01 030301 8C3Z 8009 B L87 42 33285
AWS Claim Key: 5760846 Trx Code: E84 Labor Hrs: 3
Dlr Cd-Sub Cd: 07419 - * Name: DOAN FORD, INC. Ph: 800-7821965 St:OH Ctry Cd: USA Reg Cd: NA Repr Date:21-APR-2010 Doc #:088427B
Cust Comments: CK.COOLANT LEAK AROUND RADIATOR
Tech Comments: VERIFIED LEAK,PERFORMED TSB#10 5 2,HAS VENTURI ALREADY INSTALLED ECT 194,DIDNT FLUCTUATE MORE THAN 5DEGREES. REPLACED RADIATOR, ROADTESTED OK..
1FTSW21R68EB04152 T/F7 F T/BC T/BD T/E A1 T/BE T/QL 18-APR-2007 30-MAY-2007 171424 USA 8 1F01 030301 8C3Z 8009 B L87 42 7473
AWS Claim Key: 389362 Trx Code: 1 Labor Hrs: 2.7
Dlr Cd-Sub Cd: 05432 - * Name: RANCHO FORD L-M Ph: 951-6991302 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:21-JAN-2008 Doc #:48956001
Cust Comments: CUST STATES CLEAR FLUID LEAK L F OF ENGINE AREA POSSIBLE COOLANT?
Tech Comments: PRESSURE TEST COOLING SYSTEM REPLACE RADIATOR ASSEMBLY R&I FAN SHROUD ASSEMBLY POST ROAD TEST EXTERNAL COOLANT LEAK AT BOTTOM LEFT CORNER OF RADIATOR
1FTSW21R68EB04152 T/F7 F T/BC T/BD T/E A1 T/BE T/QL 18-APR-2007 30-MAY-2007 171424 USA 12 2E02 * * * * * * 10721
AWS Claim Key: 892617 Trx Code: 08C04 Labor Hrs: 0.9
Dlr Cd-Sub Cd: 05432 - * Name: RANCHO FORD L-M Ph: 951-6991302 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:21-MAY-2008 Doc #:90178102
Cust Comments: CUSTOEMR REQUESTS RECALL 08C04
Tech Comments: INSTALLED FUEL TANK STOPPER RETEST OK
1FTSW21R68EB04152 T/F7 F T/BC T/BD T/E A1 T/BE T/QL 18-APR-2007 30-MAY-2007 171424 USA 12 6E01 * * * * * * 10721
AWS Claim Key: 892618 Trx Code: 08C01 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 05432 - * Name: RANCHO FORD L-M Ph: 951-6991302 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:21-MAY-2008 Doc #:90178101
Cust Comments: CUSTOMER REQUESTS RECALL 08C01
Tech Comments: INSTALLED CLAMP PER RECALL SEAT BACK OK
1FTSW21R68EB04152 T/F7 F T/BC T/BD T/E A1 T/BE T/QL 18-APR-2007 30-MAY-2007 171424 USA 12 7H11 120305 7C3Z 19C836 D C05 42 10721
AWS Claim Key: 892616 Trx Code: 1 Labor Hrs: 2
Dlr Cd-Sub Cd: 05432 - * Name: RANCHO FORD L-M Ph: 951-6991302 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:21-MAY-2008 Doc #:90178103
Cust Comments: WARM AIR ONLY
Tech Comments: TEST A C PRESSURES LOW LEAK TEST EVAPORATOR OK LEAK TEST ACCUMULATOR LEAKING REMOVED REPLACED RECHARGED RETEST OK BLOWS COLD OPERATING TO SPEC
1FTSW21R68EB04152 T/F7 F T/BC T/BD T/E A1 T/BE T/QL 18-APR-2007 30-MAY-2007 171424 USA 16 7D07 17XXXX 6E5Z 13466 AC L26 46 11529
AWS Claim Key: 1530493 Trx Code: E83 Labor Hrs: 0.4
Dlr Cd-Sub Cd: 05432 - * Name: RANCHO FORD L-M Ph: 951-6991302 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:10-SEP-2008 Doc #:90958001
Cust Comments: RT REAR BULB INOP
Tech Comments: REMOVED R R TAIL LAMP FOUND TWO BAD BULBS TURN BRAKE AND REVERSE REPLACED BOTH RETEST OK
1FTSW21R68EB04152 T/F7 F T/BC T/BD T/E A1 T/BE T/QL 18-APR-2007 30-MAY-2007 171424 USA 21 1F01 * * * * * * 14106
AWS Claim Key: 2708798 Trx Code: 08B06 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 20420 - * Name: PERMIAN FORD-LINCOLN-MERCURY, INC. Ph: 505-3936176 St:NM Ctry Cd: USA Reg Cd: NA Repr Date:04-FEB-2009 Doc #:17853003
Cust Comments: PERFORM RECALL 08B06 COOLING SYSTEM VENTURI TEE INSTALLATION
Tech Comments: INSTALLED COOLING SYSTEM VENTURI TEE AS PER 08B06
1FTSW21R68EB04152 T/F7 F T/BC T/BD T/E A1 T/BE T/QL 18-APR-2007 30-MAY-2007 171424 USA 21 2G01 * * * * * * 14106
AWS Claim Key: 2708799 Trx Code: 08B07 Labor Hrs: 0.5
Dlr Cd-Sub Cd: 20420 - * Name: PERMIAN FORD-LINCOLN-MERCURY, INC. Ph: 505-3936176 St:NM Ctry Cd: USA Reg Cd: NA Repr Date:04-FEB-2009 Doc #:17853002
Cust Comments: PERFORM RECALL 08B07 REPROGRAM PCM AND INSTRUMENT CLUSTER
Tech Comments: REPROGRAMMED PCM, TCM, AND IC AS PER 08B07
1FTSW21R68EB04152 T/F7 F T/BC T/BD T/E A1 T/BE T/QL 18-APR-2007 30-MAY-2007 171424 USA 35 2G05 031405 * RECAL * D36 04 36180
AWS Claim Key: 5728333 Trx Code: E72 Labor Hrs: 0.5
Dlr Cd-Sub Cd: 01418 - * Name: ANDY MOHR FORD LINCOLN MERCURY, INC. Ph: 317-8396541 St:IN Ctry Cd: USA Reg Cd: NA Repr Date:08-APR-2010 Doc #:38819504
Cust Comments: CHECK FOR RUNS ROUGH AND SURGES
Tech Comments: RUN TEST AND PROGRAM PER TSB 081602
1FTSW21R68EB04152 T/F7 F T/BC T/BD T/E A1 T/BE T/QL 18-APR-2007 30-MAY-2007 171424 USA 35 2G01 031401 * 12A650 * D36 42 36180
AWS Claim Key: 5647531 Trx Code: S07 Labor Hrs: 0
Dlr Cd-Sub Cd: 01418 - * Name: ANDY MOHR FORD LINCOLN MERCURY, INC. Ph: 317-8396541 St:IN Ctry Cd: USA Reg Cd: NA Repr Date:08-APR-2010 Doc #:38819502
Cust Comments: ENGINE SURGES OR MISSES AT TIMES ON ACCEL OR STEADY SPEEDS. NO WARNING LIGHT. CUSTOMER REPLACED FUEL FILTER. NO CHANGE.
Tech Comments: TEST ENGINE CONTROLS AND REPROGRAM PCM WITH LATEST UPDATE
