1 - 20 of 25 Posts
Automotive Lighting Experts
Discussion Starter · #1 · (Edited)
Ford F-250 Fog Light LED Bulbs
http://www.youtube.com/watch?v=Ahizt-udFMU
We carry LED bulbs for replacement of your F-250's fog lights, in all major sizes. They are available in HP, XP, and XML styles. This will make your fog lights a nice bright white that closely matches factory HIDs! Just simple plug and play, replace the bulb and you are good to go!
We carry the brightest, highest-quality bulbs at the lowest prices. Your order will ship same day, and we're here if you need us for support and service. These LED bulbs are designed by us here in St. Louis, and every bulb carries with it a three-year limited warranty.
Diode Dynamics offers several brightness options so you can choose what fits you best. These options are listed by the design and the lumen output of each bulb, compared to the factory bulb.
HP48: 265 lumens. Slightly lower brightness than factory.
XP80: 510 lumens. Similar brightness to factory.
XML2: 1410 lumens. Much brighter than factory. These are bright!
*XML2 is available in 4000K / 5000K / 6000K Color Temperature Options*
Bulb Design
HP48: This bulb is designed with 48 Epistar 3014 LED chips. Thanks to the cap on the top, the light from this High Power Bulb is shined backwards and away from the bulb, not straight out. This means the output is excellent, because it uses the vehicle's housing completely, which then shines the light much more uniformly.
XP80: Each of the four sides of this bulb contains three 5W-rated chips, and the top is fitted with four more, under a projector lens. This is the brightest self-contained automotive LED bulb on the market, and is housed in an aluminum casing with a textured finish for maximum heatsinking properties.
XML2: NEW! Two opposing genuine CREE XM-L2 chips, driven at high power by self-contained regulator unit, in an attractive cast-aluminum housing. Fully waterproof, non-polar, modular design.
These bulbs are made up of a quality plastic connector to slide right into the plug, as well as high durability terminals. A load resistor is embedded to prevent blowing the LEDs from voltage surge, and a diode is implanted to protect the LEDs from reverse polarity. The LED is wired for 12V operation, the kind found on all modern vehicles.
Included in your order is TWO BULBS (to fit your F-250).
All of our products come with a 30-day satisfaction guarantee and a 3-year limited warranty.
Click below for more info or to order:
F-250 Super Duty Fog Light LED
If you have any questions, please don't hesitate to post, PM, email [email protected] or call: (314) 205-3033
*PM us for the free-shipping code* (U.S. forum members only)
Thanks for looking!
Nick C.
Discussion Starter · #6 ·
Think all LED fog lights are created equal? Think again! Check out this comparison of our SLF LED Fog Light Bulbs compared to a generic design commonly found on Amazon or eBay. As you can see, the generic option doesn't focus the light output, causing lots of glare and wasted light. By comparison, the SLF's advanced optical design matches the filament location of the original halogen bulb, providing the same clean, focused beam pattern as the stock bulb - only much brighter!
Ready to upgrade the fog lights on your ride? Click here to use our Vehicle Finder tool!
And don't forget to shoot us a PM for free USPS shipping on any U.S order!
Jake H.
Diode Dynamics
Discussion Starter · #7 ·
Discussion Starter · #8 ·
Our Black Friday sale starts NOW! Today through Monday, 12/2/2019, save 20% on all LED upgrades including our SLF LED Fog Light Bulbs by entering coupon code "BLACKFRIDAY" at checkout!
Jake H.
Diode Dynamics
Sale ends 11:59 p.m. CST on Monday 12/2/2019. Cannot be combined with other coupon codes.
Discussion Starter · #9 ·
SAVE 20% SITEWIDE! Use coupon code "BLACKFRIDAY" at checkout for 20% off all LED upgrades for your ride, like our Pro Series Demon Eyes! Hurry, this sale ends soon!
Jake H.
Diode Dynamics
Discussion Starter · #10 ·
LAST CHANCE TO SAVE!!! Until 11:59 p.m. CST on 12/2/2019, you can use coupon code "BLACKFRIDAY" at checkout for 20% off your entire order of lighting upgrades, including our SLF LED Fog Light Bulbs! Don't wait, this sale ends TONIGHT!
Jake H.
Diode Dynamics
Discussion Starter · #11 ·
Our Memorial Day sale starts NOW! Today through Friday, 5/29/2020, save 20% on all LED upgrades, including our SLF LED Fog Light Bulbs by entering coupon code "USA20" at checkout!
Collin
Diode Dynamics
Sale ends 11:59 p.m. CST on Friday, 5/29/2020. Cannot be combined with other coupon codes.
Discussion Starter · #12 ·
There's no better time to upgrade! Through Friday, 5/29/2020, get 20% off all our LED upgrades for your ride, including our Fog Light LED Bulbs with coupon code "USA20" at checkout!
Collin
Diode Dynamics
Sale ends 11:59 p.m. CST on Friday, 5/29/2020. Cannot be combined with other coupon codes.​
Discussion Starter · #13 ·
LAST CHANCE TO SAVE!!! Until 11:59 p.m. CST on 5/29/2020, you can use coupon code "USA20" at checkout for 20% off your entire order of lighting upgrades, including our SLF Fog Lights!!! Don't wait, this sale ends TONIGHT!
Collin
Diode Dynamics
Discussion Starter · #14 ·
Our July 4th sale starts NOW! Today through Monday, 7/6/20, save 15% on all LED upgrades, including our SLF LED Fog Light Bulbs by entering coupon code "JULY4" at checkout!
Collin
Diode Dynamics
Sale ends 11:59 p.m. CST on Monday, 7/6/20. Cannot be combined with other coupon codes.
Discussion Starter · #15 ·
This is NOT a drill! Our Black Friday sale starts NOW! Today through Monday, 11/30/2020, you can use coupon code "BF15" at checkout to save 15% on all LED upgrades, including our Fog Light LED Bulbs.
Collin
Diode Dynamics
Sale ends 11:59 p.m. CST on Monday, 11/30/2020. Cannot be combined with other coupon codes.
Discussion Starter · #16 ·
Don't miss out on our lowest prices of the season! Through Monday, 11/30/2020, get 15% off all our LED upgrades for your ride, including our Fog Light LED Bulbs.
Use code BF15
Collin
Diode Dynamics
Discussion Starter · #18 ·
We recently released a video explaining the differences between lumens, lux, and candela and which of the 3 determine the true output of an automotive LED bulb or lamp. Check it out above!
Also, don't forget to PM us for free standard-economy USPS shipping!
John C.
Diode Dynamics
Discussion Starter · #19 ·
Our Memorial Day sale starts NOW! Today through Friday, 6/4/2021, save 15% on all LED upgrades, including our SLF LED Fog Light Bulbs by entering coupon code "USA15" at checkout!
John C.
Diode Dynamics
Sale ends 11:59 p.m. CST on Friday, 6/4/2021. Cannot be combined with other coupon codes.
Discussion Starter · #20 ·
Our July 4th sale starts NOW! Today through Thursday, 7/8/2021, save 15% on all LED upgrades, including our SLF LED Fog Light Bulbs by entering coupon code "JULY4" at checkout!
Plus, all orders over $300 will receive a free Diode hat!
John C.
Diode Dynamics
Sale ends 11:59 p.m. CST on Thursday, 7/8/2021. Cannot be combined with other coupon codes.
1 - 20 of 25 Posts
