7.3 Turbo
Garrett 38R 1535.00 to your door
Tec Stage I 995.00
Tec Stage II 1250.00
6.0 Turbo
Tec Stage I Variable White Lighting 1500.00
Tec Stage II Variable White Lighting 1650.00
All prices include shipping.
Aden
Any information on these Turbos? Chris
What are they comparable to? Do you have a link to any specs.?
I can get you all the information. Which turbo do you want the information on.
Aden
Both. What are the differences between the two stages and as compared to stock? What will they support? Are they based off of the OEM Turbo?
The Stage I/White Lighting is a 62mm inducer/87mm exducer Compressor Wheel and flows 53lb/min at a 2.5 pressure ratio. Also, has a efficiency of 74%.
The Stage II/Silver Lighting is a 64.7mm inducer/88mm exducer Compressor Wheel and flows 60lb/min at a 2.5 pressure ratio. Also, has a efficiency of 72%
Both upgrades come with.
Upgraded 6 pad 360 degree lubed thrust structure. This replaces the standard 270 degree thrust bearing.
Upgraded VNT Rollerless type actuation valve. Eliminates the stock actuation valve, which is known for making the vanes stick.
We do need the core back.
