Found remedy for leaking freightliner fuel cap's without having to buy expensive new one's.You will need a freeze plug(I found mine at O'reileys Pt#555-031 under Dorman brand cost $.65 ea. )then discard chain and hammer freeze plug to cover hole,Cheap fix and it really work's especially for those out there that want to keep tank's clean, mine have not leak for over 3 years and I fill them all the way to the neck....BTW make sure vent hose is not clogged..FYI,this will only work on the twist on cap...
For those that want to keep chain on cap,my buddy drilled a hole threw freeze plug lined up to hole in cap for chain wedge. (Wish I could post how-to pic's but I'm not that talented)
