Does someone make a kit with everything needed to rebuild the front suspension on the 2wd trucks? Or is it a piece by piece deal at my local parts store? I've search and found nothing, also a friend of mine did his and told me he wanted to end his life halfway through it, is it really that bad?
Ya if nothing has been changed for a while. I re-did everything on my 2wd. Make sure you have the tools to do the job. I'd just buy all MOOG stuff. I saved a post on another website that has all the part numbers so you can just order online if you want. I think it was comp diesel .com or something I got these from. It's a job that might take ya all day, but the end result is very much worth it. It'll drive like a wet dream. When I re-did mine I did brakes, struts, bearings everything though.
moog numbers:
94-02 2wd part numbers:
02-94 adjuster sleeve: ES2080S
99-94 adjuster sleeve: ES2080S
02-00 tierods: ES3540 outer right, ES3539 inner right,
ES3539 inner left, ES3540 outer left
99-94 tierods: ES3172RLT outer right, ES3171RLT inner right,
ES3171RLT inner left, ES3172RLT outer left
02-00 solid axle 3500 HD tierods:
PITMAN ARM TO RIGHT HAND STEERING ARM: right hand connecting tierod DS1460,
adjuster sleeve ES21012S, pitman arm tierod ES3527.
LEFT HAND STEERING ARM TO CONNECTING TIEROD: connecting tierod DS1462,
adjuster sleeve ES21012S, left tierod ES3526.
99-98 solid axle 3500 HD tierods:
PITMAN ARM TO RIGHT HAND STEERING ARM: right hand connecting tierod DS1459,
adjuster sleeve ES21012S, pitman arm tierod ES3497.
LEFT HAND STEERING ARM TO CONNECTING TIEROD: connecting tierod DS1456,
adjuster sleeve ES3498S, left tierod ES3496.
track bar: DS1413, replacement bushing: K7252
97-94 solid axle 3500 HD tierods:
PITMAN ARM TO RIGHT HAND STEERING ARM: right hand connecting tierod DS1309,
adjuster sleeve ES21012S, pitman arm tierod ES3249RT.
LEFT HAND STEERING ARM TO CONNECTING TIEROD: connecting tierod DS1308T,
adjuster sleeve ES21012S, left tierod ES3248RT.
track bar: DS1256 before 2/7/94, DS1413 after 2/7/94, replacement bushing K7252
99-94 solid axle 3500 HD REAR tracbar K7382
02-00 upper balljoint: K7366
99-94 upper balljoint: K7206T
01-00 lower balljoint: K7365
99-97 lower balljoint: K7269
96-94 lower balljoint: K7205T
99-94 upper control arm bushing kit: K7276(2 per truck)
99-94 lower control arm bushing kit: K7277
2WD STRAIGHT AXLE 3500HD:
02-00 upper balljoint: K7397
99-94 upper balljoint: K8388T(enhanced design)
02-00 lower balljoint: K7397
99-94 lower balljoint: K8607T(enhanced design)
99-94 upper control arm bushing kit: K7278(2 per truck)
02-94 swaybar link kit: K7275
99-98 3500 w/ straight ball stud swaybar link kit: K7300
99-96 3500 w/ tapered ball stud w/ solid axle swaybar link kit: K7280
97-94 3500 w/ straight ball stud w/ solid axle swaybar link kit: K7299
97-94 3500 w/ straight ball stud w/ solid axle swaybar link repair kit: K7300
***PM ME: for swaybar to frame bushing kits, too many to list***
02-00 2500 w/ 7500lb GVWR idler arm: K7347, pitman arm: K7345
99-95 2500 w/ 7500lb GVWR idler arm: K7217T(HD), pitman arm: K7239
99-95 2500 w/ 8800lb GVWR idler arm: K7225T(HD), pitman arm: K7238
02-00 3500 IFS idler arm: K7347, pitman arm: K7345
99-95 3500 IFS idler arm: K7225T(HD), pitman arm: K7238
1994 2500 w/ 8800lb GVWR idler arm 2nd design 16mm bolts: K7225T(HD), pitman arm: K7238
1994 2500 w/ 8800lb GVWR idler arm 1st design 14mm bolts: K7237, pitman arm: K7238
1994 3500 IFS idler arm 2nd design 16mm bolts: K7225T(HD), pitman arm: K7238
1994 3500 IFS idler arm 1st design 14mm bolts: K7237, pitman arm: K7238
moog numbers:
94-02 4wd part numbers:
***ALL NUMBERS ARE FOR DANA 60 AXLE***
02-00 trackbar: DS1413
02-00 tierods:
99-98 trackbar: DS1413
99-98 HD tierods:
97-94 trackbar: DS1256 before 2/7/94, DS1413 after 2/7/94, replacement bushing K7252
02-00 pitman arm: K7339
Advanced Auto Parts is suppose to start stocking the stuff in 2008 sometime. Is that true? I doubt it. But that's what they say.
I figured someone would've had a kit put together with everything already.
Probably the reason there isn't a kit is because some of the individual parts cost alot! The Pitman arm I think runs around 100 and you don't want to buy a whole kit just for the pitman arm. A kit might cost 1000 bucks.
I priced buying everything individually at the parts store and it was about $700 +/- if I remember right.
Well alittle FYI on parts stores, Autozone used to carry Dana parts, then they just kind of re boxed their own junky ball joints and tie rods in Dana boxes. I don't even know if they still do that, I think it's just Duralast now. I think they've done away with Dana. Advanced is suppose to be stocking Moog which I'm a big fan of, but I'm not seeing anything. Not sure what Napa is but that's what my Idler and Pitman arm were on my 98 and did run into an issue with their Idler if my memory serves me correctly. That probably doesn't help you. But I figure I'd throw that out there.
