Wondering if anyone has ever had problems with a module ,it shows a p0201 code . stars right up but droppes a couple of cylinders, checked wireing and did some tests checking wires with a ohm meter shows that everthing is ok.any ideas ??????
Nasty Girl
Had the same problem awhile back. It was a connection to the module. Not likely you have a problem with the module itself they rarely fail.
