Yep, exactly what I thought. You'd rather argue than admit that you're earlier comments were condescending.know how,they being EPA control us now,will that truck pass emissions,we have to conform to the epa standards first ,formost,built many that were very very impressive ,cat makes all the parts to do it ,marine cams ,turbos,just EPA,alot of the driver technicians turn fuel to one ,before they actually know what is wrong,seen pittsburg power boxes put on ,covers up original problem ,but it all ways shows it ugly head,now repair is costly ,nothing against a hot rod ,c-16s with 2000 hp ,is easy ,problem EPA, I NEVER REALLY NEEDED HELP FIXING AN ENGINE ,STILL DONT, ANYONE CAN BUY A BIG BOSS ECM, GETTING ALL THAT HP ISNT THE PROBLEM ,ITS RELIABILITY AN SERVICE,
LOLtry to help fix the problem the guy has,not sell a 15 to 30,000 dollar overhaul,making hp isnt the problem,all engines ,same engine in marine 2 to 3 TIMES hp as truck,can be done with cat parts,impress me by fixing a problem by not turning the fuel to it ,you cant,the reason for dyno is to meter fuel ,go as high as possible an keep in EPA WINDOW,BY CHANGING FLS -FTS THAT CHANGES FUEL ,TIMING ,WOW IS THAT HOW YOU GET HP AN TQ,METERING FUEL IS HOW YOU CHECK IT RIGHT,AN CHANGE,RECHECK , ,DID THEY SHOW YOU ON DYNO ,HOW TO DO THIS ,OR YOU READING FROM A PAMPLET,YOU GOT AT PERFORMANCE DIESEL [PDI],YOU ARE A TYPICAL KNOW IT ALL DRIVER
LOLFIRST READ BMOELLER MEMBER ON PAGE 2,NOW THE FIRST THING IS EPA W9L AS FAR AS MARINE NO PROBLEM GETTING POWER AN TORQUE,AN KEEP IN EPA STANDARDS ALSO CARB ,DO YOU KNOW THESE PEOPLE,I PERSONALLY HAVE BEEN TALKED TO BY THESE PEOPLE ON PHONE ,BECAUSE I WORKED ON TRUCK.NO WORRIES ,MY EXPERIENCE WOULD PROBABLY AMAZE YOU,IF YOU DONT WANT MY ADVICE DONT READ POST ,MY INFO DEAD ON ,IF I AFFEND YOU ,MAYBE YOU SHOULD QUIT WEARING YOUR FEELINGS ON YOUR SHOULDER,I POSTED SEVERAL TIMES HERE WITH ADVISING PEOPLE TO GET A GOOD CAT MECHANIC BECAUSE KNUCKLEHEADS DONE SCREWED HIM OVER,IN THIS DAY AN TIME,MAYBE THESE GUYS NEED DEAD STRAIGHT ADVICE WITH THERE ENGINE ,THE MOTTO PAY NOW GET IT RIGHT THE FIRST TIME,NOT 3rd OR 4th,now fls an fts changes fuel position an rated fuel position,all of these are determined to a point by the specific torque curve an rpm,by changing these you get a wider or longer pulsewidth,thru ecm an info from certain sensors,[do you know which ones],this has to be there before your PDI ECM WILL DO ITS JOB,that in turn changes voltage to injectors [do you know if it is [ ac or dc]if you dont want my advice dont read posts,AGAIN, PDI FLASH IS IT 3200$,I WOULD CHECK A FEW THINGS BEFORE JUST THROWING MONEY AT IT,DONT KNOW HOW MANY TRUCKS IVE WORKED ON STAYED LATE ON BULL WAGONS,FIXING KRAP THAT SHOULDVE BEEN REPAIRED BEFORE THEY FLASHED ECM,INJECTORS, CAM ,TURBOS,THINK REALITY ,THE GUY HERE NEEDED HELP WITH HIS TRUCK ,HE MAY RELY ON HIS TRUCK FOR A LIVING,I HELP THE ONES WHO NEED HELP ,YOU DONT ,RIGHT YOU ALREADY KNOW MORE THAN CAT,OR ANYONE ELSE,OH YES BEEN OUTSIDE BOX MY WHOLELIFE,AGAIN DONT READ MY POST .I THINK I NOTICED THESE NAMES ON A RECENT POST ,LOOK OVER BIGMACHD.GET ALL YOU PDI INFO ,BUY A CAT MANUAL ,COMPARE ,WONDER WHO COPIED
Any of us that are truck drivers, that actually know anything about our trucks, is because we largely also work on them, and learned as we went. We also aren't run of the mill steering wheel holders that have to ask permission to take a piss. I started turning a wrench when I was 8 yrs old.just amazed how much truck drivers know,really amazed,how long do you have to drive a truck to become a good mechanic, real mechanics are in high demand ,go by cat dealer get job app ,you will do fine
You still don't know why the ECM varies the voltage........do you?varying voltage an pulsewidth opens solenoid ,longer ,shorter,as the demand changes an or is ask for by the ecm per flash an fuel #s,not reading sis or service manual ,was i that close,maybe learned something at refresher class fuel mileage can be simple or complex,ive seen poor fuel mileage fixed by fixing CAC leaks,actuator on turbo ,or as simple as program ,run overhead,or with set up of truck driver running 1 gear down on a 13 or 18,setting govenor for use either at 1800 ,or 2100,do you understand about govenor if not ask,from first E-model to accert this matters ,i dont really think there is a common problem ever for fuel mileage,it could even be the trailer hes pulling ,no air fairings ,look if what ive said got you tore up ,i hope no one ask a complicated one,loose your feelings,it will be easier,about drivers most tell you they know ,you hear it every day,dont you,i just send most to driver lounge,high horse not me ,i just tell like it is no sugar coating,thats from to many 100 degree days ,really run me out of town ,ha ha ,
first line ,do you understand post ,reread
