What is the max pressure between the air dog II-165 and the cp3? Im running 17 psi. Right now. Can go as high as 45psi. I have the stock canister bypassed and hoses and fittings are good for over 300 psi. And will it help or hurt to run higher psi? If so where is the sweet spot. Thanks for help.
ADMIN/MAFIA
I run 16 psi, but if your between 15-18psi your good.
CRAZY CANUCK
It really depends on how much fuel you need for your setup...if your truck is stock with a tune then 16psi is plenty
CRAZY CANUCK
Bully dog tuner run it in performance tune. K&N filters but stock other than that.
You should be good where your at :thumbsup
