1 - 16 of 16 Posts
WANNA SMOKE!!!
Im looking at the Glow Shift gauges in white and obviously I am getting the Pyrometer and Boost gauge but was wondering if the Fuel Pressure gauge was the correct one for my truck. Im in the process of upgrading to a Smarty, MP-8, Fass, Southbend, and DDP Injectors and need advice to see if this is the correct FP gauge. Thanks
I don't know all that much about guages, but I will warn you with those mods you better be doing something fuel wise to hep out your cp3, the fass won't cut it for much longer I don't think, sorry I oculdn't help more
WANNA SMOKE!!!
Discussion Starter · #3 ·
Well what would be the next fuel upgrade? Im not new to the Diesel thing but i dont know a whole lot yet. When i go down to the local diesel mechanic, all he wants me to do is spend spend spend and not help me out any on what mod i should do next. Any help would very appreciated.
Mafia member 46
the question is how big of injectors are you putting in? IMHO anything over 50 hp needs a modded CP3
WANNA SMOKE!!!
Discussion Starter · #5 ·
Such as a BD Lift pump kit? As far as the gauge, anyone ever heard of using an isolator so that diesel doesnt come inside the cab?
no, no lift pump, what you need is a hot rod cp3, otherwise you will drain the rail to a bad extent, look at industrial injection.com and there are others, you're looking to replace the whole unit, the stocker just won't keep up
WANNA SMOKE!!!
Discussion Starter · #7 ·
Gotcha!!!! Im looking at them now. Just dont know whether the modified, stage III, or Super is what i need.
WANNA SMOKE!!!
Discussion Starter · #9 ·
90 Hp Injectors. In the future i am planning on Twins but i dont Sled or Drag. Would the modded be ok with Twins?
im running the 90 hp injectors, mp-8, smarty, and i still have over 20KPSI at WOT. i just have the DIY CP3 mod.
I don't know, I wouldn't do the DIY, I've heard of quite a few people who do it wrong and mess the pump up, IMO you're better off investing in a full aftermarket pump
WANNA SMOKE!!!
Discussion Starter · #12 ·
Yeah im going to go ahead and get the Mod. CP3 from Industrial. Thanks for the help guys
TDG Mafia - Booze Runner
cummins2jz said:
Are you guys are still running the FASS with the modded cp3?
GO with a Glacier Pump!!!
WANNA SMOKE!!!
Discussion Starter · #16 ·
Whys the Glacier so good? Just asking because im up for all kinda options
1 - 16 of 16 Posts
