Thanks in advance to everyone who has helped me so far.
I am still not happy with the fuel pressure gauge that I have rigged up. I have an el-cheapo 16 PSI gauge from advance auto plumbed into the fuel filter cap. I HATE the copper tubing I used, and I am looking for alternatives. With the straight copper the gauge is terribly noisy, I can't even hear the turbo anymore over the gauge rattling.
The usual readings that the gauge is showing (which may or may not be accurate) are 6-8 PSI when travelling, and maybe 10-12 when idling. I am pretty sure that the reading I am getting is dangerously low? I have the superchips tuner on the LOWEST setting, and have cold-air intake and 4" straight exhaust.
Here is the current dilemma. I am going on a trip this weekend, and I need to get things squared away before then. What do I need to do NOW, without breaking the bank. I really don't have time to order parts, unless I know they will be here by friday.
I'm thinking that I need some better fuel line, to quiet the gauge, and it may give me a more accurate reading.
I'm not using the superchips for high-performance right now, it is on the TOW-SAFE (lowest setting) just so I can adjust the computer for tire height (correct the spedometer reading) and get better fuel milage.
I know that these things cost money, but I am broke and can't afford a bunchy of fancy stuff...yet. All of the mods that I have now, I got either used or by nabbing good eBay deals. I also bought them for the purpose of more economical engine performance, and cooler EGT's.
So, in summary, what do you suggest that I do (or not do) to keep things running smoothly for my trip this weekend? Or am I silly by thinking that there is a problem to even worry about?
TDG Mafia 57
Replace the copper tubing with plastic tubing and get an isolator, for the gauge. You should be able to get the plastic tubing from the hard wearer store or from a truck supply store . As for as the ice try your local hydraulic supply store. They should have something like this to help you out. All in all all the parts should not be no more than $ 60.00
The isolator, works by taking the fuel in one side and pushing on a diaphragm and then pushing on another fluid ethylene glycol and that goes to the gauge in the truck to give you the pressure reading. A good hydraulic shop should have everything you need.
Hope this helps.
Another solution would be to make a low Fuel pressure light. You can get a tapped banjo bolt from GDP for about $9 and you can get a hobbs N/C pressure switch for about $15, get it preset to 6psi. Then run an LED into the cab triggered by the hobbs switch, if your fuel pressure gets too low, the light will light up. GDP should be able to get you the banjo in a couple of days, or you may be able to find it at your local Napa store as well. Or what truckie said would work fine as well. I wish I had known about getting the isolator from a hydrualic shop, I paid over $100 for one from autometer.
B
Good advice above, you might find your pressure a little higher once the gauge is properly installed. If not you can always install another factory lift pump or a Holley pump oy your choice. Although the Holley is going to take you a little longer.
Depending on which port you tapped into on the head, you could be seeing FP down stream of the filter...might need the filter replaced...
steved
