1 - 20 of 21 Posts
How many gallons of diesel are you able to put into your truck? I can never get more than 22 gallons in from the low fuel light. Is that because the low sulfur diesel foams up so much?
I've put 29 almost 30 gallons. Thats the most. I'm not when the light comes on. I think 28 at least.
Reactions: Rosco
short bed trucks are 29 gallons
long bed trucks are 38 gallons
I can get 92 gallons in my truck when i fill up (but thats another story) !
your problem is with the VENT tube in the tank...it protrudes too far
into the tank & liquid fuel. When filling the tank, the liquid rises to a point
eventually covering the vent tube in the liquid level which prevents VENTING.
you need to HARPOON <mod> your tank - Harpooning is an easy
mode (drive the tank level low/close to empty), drop the tank and
SNIP the vent (and fill) line that extends too far into the tank/liquid
youll fill your tank FASTER, venting it quicker, and youll be able to fill
the tank COMPLETELY !
the VENT is the yellow poly/pvc pipe in this photo -
BEFORE ->
VENT cut ->
VENT AND FILL CUT ->
Detailed instructions are HERE
Auto's are for pansies
Are you filling it until it clicks only, with no top off?
I top mine off until there is a visible fluid level in the filler neck, no foam. The highest I've got on my short bed was 31.XXX. And I was dang near empty
Reactions: Rosco
Thanks, after reading your responses I filled the truck slowly and was able to get 25 gallons from the 1/8 tank mark.
good deal...and important thing to know is that the tank in our DIESEL trucks is
the very SAME tank that is used in the gasoline trucks...so the vent tube might
be better suited (as is) for gasoline vapors and expansion.
if you "harpoon" the tank youll be able to get more fuel in, FASTER.
Reactions: Rosco
I'm looking at getting a Titan fuel tank when I get back from Iraq. Do you know if the Harpoon mod work with it as well?
couldnt tell you. i do know that they use the at least some of the OEM
internals (sending unit etc). they require you to use or move the OE float/sending unit to their tank at installation.
I dont know if they (or anyone else) have designed shorter, internal, vent
lines.
Im curious - what truck do you have (long bed ? short bed ?).
When you consider the cost per XTRA gallon these factory replacement
tanks (transferflow & titan) are REALLY REALLY expensive.
look at the following integrated systems and tanks -
http://attatank.com/atta/
http://www.kshmarine.com/truck_tanks1.htm
for the cost of a titan or trasferflow you can have 50+ gallons or MORE,
not just 15 or 20 more.
Whipersnapper
While I completely agree that they are more expensive per extra gallon. I know in my mind that an OE replacement vs an addon is what I would want. It is the same reason I spent the money to get the audiophile system vs getting a better one installed for cheaper after purchasing the truck.
just because its OEM doesnt mean its better...plastic tanks and factory
audio systems are a PERFECT example of reduced cost lower quality
examples.
lines.
I have a short bed. If I had a long bed then I would look at an in bed tank. As much as I drive my truck when I'm home I would like not to have to fill up as often.
I have a short bed, needed a toolbox, and a bigger tank, and I got both in one package, with minimal bed room taken. 40 extra gallons over stock, and a toolbox, and only a little over a foot of bed room taken, that's the only way I found feasable. If I had a long bed, I will say, I'd have a skinny aux tank in front of a full toolbox. I can't justify spending $XXXX on replacement tanks that don't add a helluva lot of fuel.
and you can either take that in bed tank w/ you to the next truck
or SELL it later if you want...not only does an in bed tank provide more
fuel at less cost, but it also provides RESALE value and is not BRAND
specific or truck model year specific.
The DUDE!!
I want both... then i can have even more than the fuelmiester Don!!!
TITAN TANK (51 gal) + Aux tank in bed (50 gal) = 101 GALLONS !!! That's what i want to do... just can't justify either one right now..... :(
wants and needs - the primary struggle of my LIFE ;)
what EVER you do...KEEP your OE tank...you can re-install it
later, when / if you sell the truck...and sell the titan and recover
some of the costs.
Yep, I've already let mine drain as best as possible, and I took out all the wiring Sunday, so it doesn't function anymore. Now all I have to do is unbolt it from the bed and disconnect the filler tube, and my tank/toolbox is out of the truck, and either on the market or on the next truck.
The DUDE!!
some of the costs.
Ain't my first rodeo.....
hmmmm..... someone needs tires... and someone wants a fuel tank/toolbox.. hmmmmmm:haha
willie makes a good point and a CLEAR advantage of in-bed tanks....
IN BED tanks are INTERCHANGEABLE between FORD/DODGE/GM trucks...unlike OEM,
under truck replacement tanks which are certainly more limited to specific MAKE MODEL &
YEAR in their potential REUSE or RE-SALE !
The DUDE!!
well for me, an replacement wouldn't be that bad. We keep our trucks for a long time and put lots of miles on them.. my 05 6.0 has 115,000, 99 7.3 has 140,000, 93 dodge has 3xx,xxx on it, 02 dodge has almost 100,000 on it..... and all of them are still driven on a regular basis with no plans to stop.
That is why i want both in mine :thumbsup
Actually, you made that point earlier. :D
I thought since mine automatically refilled every so often, that it had special wiring harness or fancy system. Hell no, it was one wire stuck in my fuse panel, two wires spliced into a single wire out of the harness under the truck, and a ground on the frame. Wow. I could wire that up on a go cart. LOL
1 - 20 of 21 Posts
