I'm wanting to get gauge pods for the piller. Just wondering how you all ran the wires/Hose for boost from the engine compartment to the piller? Thank Dave
Drill a hole thru the fire wall... If your an auto there is a blank plastic port for the clutch master that most use... Pyro I run down thru the floor at the auto cable port...
i ran all mine thru the firewall...you should be able to go thru some of the
existing rubber plugs. I used an ice pick (or awl) to poke a small hole in the
one of the existing rubber fire wall plugs...just something to get it started...
you dont want too large a hole, dont want it to leak !
Smokin'
Existing holes in the firewall work.
