i got some general maintance questions and some questions in general i have a 1990 f250 7.3 4x4
1 how much oil does my engine take
2 how much tranny fluid does my trans take its a e4od
what is the nornal tranny temp
also what would be a good size exulst to put on my truck
im pretty sure it takes about 2.5 gallons of oil and the exhaust on my truck is 3 inch and it runs and sounds good.. hope this helps a little bit
If changing your oil you can use the 7.3 D.I. filter ( motorcraft # FL-1995 ) for more filter substrate and oil capacity too.
Super Moderator
That's an EXCELLANT suggestion, I have done exacatly that since the PSDs were introduced, use the larger PSD filter on the IDI engines.
The Wix/NAPA PSD filters (51734/1734) also filter out smaller particles than the IDI filters (51742/1742.)
