DTC code #5 cylinder glow plug wiring malfunction. i cant remember the code number but the code description is what i remember.
can i assume the Dmax is numbered the same as other chevy blocks with #5 being the 3 cylinder from the front ontthe drivers side?
what issues cause this? bad plug? or is there a seperate code for a bad plug? thanks for any help
CRAZY CANUCK
no the duramax is swapped, odds on passenger side, evens on drivers side starting from front to back
Reactions: Billu
Pardue the Traveler
yep what he said, I had my #8 replaced and it was on the driver side by the firewall. the bad glow plug code I got was P0678
truckn'
i just replaced my #8 also, it was easier to lay on the ground and reach up then from the top side. I like that the computer tells you what one it is, not like my old 7.3 where you just replaced them all...
