alright just got some new glow plugs for my obs never done them before....? wonderin if anybody has any pointers??
Test the GPR first. If you still need to change them, they are not too bad once you get the VC off. The passenger side is a pain. Check out the wiring and plugs while you are in there and replace anything that looks suspect.
I replaced my own...Take's forever to get to the valve cover LOL
Passenger side sucks.
To get a little more room on the passenger side there is a small rectangle box with a vacumme line going to it, that is bolted to the side of the air box with a couple of small srews. It may be covered with a piece of insilation but you can have it off in about 30 secounds and it will give you a couple more inches of room on the those back bolts. also look those valve cover connections over real good its pritty common for them to cause problems
the plugs on top of the valve cover i heard most of the time are the problem not the plugs themselves ill check them out this weekend and see whats up thanks guys
My outside plugs where good, it was the inside on mine that was the problem!!
