1 - 20 of 24 Posts
· Junior Member
Dealer installed the 2006 Air Box on my LLY. Unlike some of the LLY owners who have had it installed and had problems, my truck continues to run great. At this point other than running cooler when OAT in 60ties no real changes. MPG improved about 1 mpg. Took 250 mile run to deer lease loaded with 900 lb of feed/tools. Left at 4AM with temp at 68 and no headwind. 21 mpg on run up to lease with LLY temp at 190 and normally runs at 205. On return trip in the afternoon with with OAT 94 deg, LLY temp ran normal at 205 and ended the trip with 19.7 mpg.
· Senior Member
Looks like a clean install. Are you happy with your with the dealer's workmanship?
· Registered
Sea04DMAX said:
So the rumor that they were screwing with the ect gauge so it reads cooler is false??
That depends. I have never seen evidence that they have manipulated the gauge, but they have definitely removed audible alarms and the way the alarm message is displayed in the DIC along with moving the alarm point much higher up.
· BUG JUICER and
YES, very literally false.
The GM ECT gauge behaves consistently with just about EVERY coolant gauge ever produced, to be informative without drawing attention to itself when thermostats cycle. If anything, ours is more sensitive than most. Next time you are not in a duramax take a look. Japanese, German, Swedish, thay are all the same. The gauge rises very quickly, within 5 minutes, to a fixed point around 20 degrees shy of the thermostat cracking temperature, and never moves. I have driven civics that ran at 200-230 degrees all day in Phoenix city traffic, electric fan cycling, with oil at 300 degrees, and nary a sign of anything out of the ordinary.
ALL these gauges are INTENTIONALLY fixed with a large dead zone, 30 to 50 degrees wide, where the needle parks itself forever, moving only to illustrate what the OEM intended it to show, severe undercooling or overcooling of water based coolant. This is done because it is a passenger car, not the Space Shuttle Challenger, and because the gauge is not a diagnostic tool. OEM's hate gauges because they create work. Intended only to be mildly more informative than a dummy light, with graduated markings that promote the same intelligence as most of its operators ( :) a forum cross=section is not representative of this IQ, most of whom are quite a bit more knowledgeable than average tow Joe :) )
GM changed the deadband a year ago, in response to ECT complaints, many of which came from people whose vehicles only got warm. NOT OVERHEATing, as in no loss of coolant, just get hot. With some exceptions, few actually get coolant to spill, but many get the DIC notification. The corporate response..."lets pretend the problem doesn't exist, mask it more and we will reduce these nuisance calls by 50%". That is what I would expect from GM, there is no money in fixing issues when the check has been cut. Ethically, its a debate, but the acts of GM to deal with the service call issue, are very appropriate and common. Deny, deny, deny
These people came in and there was nothing GM deemed appropriate or cost effective to fix it. So they went with reducing the visibility of the issue. How? They deadened the warning system a bit more. Grandstanding conspiracy supporters say they added deadband to the gauge so it behaves ("lies") more like a typical consumer oem gauge. Unproven, however IMO, irrelevant. They also raised incidence of audible alarms by 4 degrees, 244 to 248 IIRC, in one act. That much can be viewed in the ECM code.
The relevant fact is, if you get hot enough to spill coolant, the gauge WILL tell you beforehand. It has always done this, and GM did nothing to inhibit it from notifying the operator thus. The graduated markings are worthless, and they always were (like every oem gauge), just as they are in every other car out there. 160 is not 160, But 205 is 205 with +/-15 degree certainty.
A dummy light with trend information.
· Registered
GM eliminated my first audible alarm which was "Engine Coolant Hot" in the DIC and while they were at it they moved it from the original LLY 246*F alarm point up to 253*F, which is only 2* below the 255* "Engine Overheated" alarm point in the DIC display. They then take the stance that if the truck does not alarm, there is no problem. :)
Now, you can be the judge yourself of whether or not you believe those are the actions of a company who is trying to help you, or is trying to hide a problem from you ;)
· Registered
As for the story about Hondas, I have a 2005 Accord, and its temp gauge behaves nothing like the colorful narrative given above. It moves rapidly and fluently to temp swings. I checked all of my vehicles, and 7 different rental cars, in an effort to see if any of them operated similar to the gauge in my Duramax truck. Contrary to what is posted above, the various gauges and displays were responsive and reasonably accurate. There is no common 30* - 50* dead area, thats nonsense. The new GM vehicles actually display the exact temperature in the DIC, and I have monitored the data buss and they are spot on and move together.
Often its best to actually try these things out instead of just reading about them in books and then regurgitating what some book said ;)
· BUG JUICER and
Some of the retrofit vehicles have suffered performance and code issues. It was determined that some of the techs, either skipped the reflash step, or were not familiar enough with it. I have had good luck with the CAI I developed last summer, and it is similarly effective. After it is installed, it almost can not be differentiated from original stock. It is also considerably cheaper and requires no reflash.
There is more information on how this (CAI) improvement is essential to the cooling system.
Harmful Feedback Loops
I also have 2 of the new LBZ intakes, brand new, if anyone is interested, but you need a way to change MAF scaling, EFI can do it, an easy change to make.
· Registered
I have been looking for these on ebay but haven't found any. PM me a cost. My truck has not overheated yet but i just got it a couple months ago and summer is coming.
Steve
· Registered
In the long run it would be a smarter move to go with killerbee's intake mod or some other modification of the stock box. The performance is similar to the 06 box but the cost and availability of the 06 air filters will burn you over the long haul. The 06 box also will come from GM with temperature alarm alterations that will not let you know if you have a cooling problem until it is too late.
1 - 20 of 24 Posts
