Well my trailer is now five years old and in need of a good reflooring. I was wondering what kind of weight savings I could have from doing it in aluminum versus the treated 2X8's
I'm also planning on using apitong boards over the axle where I put most of the small yet heavy freight. I think they are stronger and would make me feel more comfortable when hauling vertical motors, totes of corrosives, etc, when there is that much weight in a small amount of space.
So i guess the question is are the aluminum/apitong flooring going to save me enough weight (1000+ pounds) for it to be worth the extra cost. The added strength over the axles would be, but I'm trying to justify doing the whole trailer.
Thanks
Shay
Not sure on the type of trailer you have...what is your primary use for the trailer?
On our lowbeds we sometimes deck customers trailers with alum truck frame with 2 x 2 x 1/4wall tubing under to suport the alum. Normaly just the 2 ouside boards are replaced with alum then the next boards next to the alum would be apitong then the remaining would be doug fir. With the price of alum nowadays I dont know if I could justify doing it to our own trailers. The wrecking yards around here are wanting around $25 and up per foot and getting harder and harder to find since alum framed trucks are no longer built. If it was me I would just stick to apitong on the 2 outside then doug fir in the center and roll with that..maybe throw a coat of wood sealer on and good to go.
Thanks
Shay
