F
Took a couple pics for information purposes while towing. Not sure what the total weight was, I know my dually weighed 8500lbs at Merchants last spring + 100g of fuel @ 6lbs or so.
9100
7600 - LB7
700 - weights
plus tires, boxes, tools, jacks, etc.
trailer
Pics took on level ground while cruising at 70mph.
Rail Pressure - 21K
Boost -10psi
EGT - 1050*
MPH - 70
RPM - ~1850
Tranny ~ 195
Water - 205*
Mafia member #105
looks like you need to shim your fuel pressure valve light should of been a p0087 with the 21,000k rail pressure.
F
dazed&confused said:
Why is your engine light on?
Exhaust back pressure, EGR thing. I have never installed my blocker plate.
F
Why is that? The light only comes on when towing. I can hit 28K psi. (assuming the gauge is accurate)
Mafia member #105
Was saying that after seeing your list, LOL I use to code while towing thought that was what you were posting pic of Wayne.
Rail Pressure - 21K
Boost -10psi
EGT - 1050*
MPH - 70
RPM - ~1850
Tranny ~ 195
Water - 205
