I know you can go hog wild with guages and pods but what are the three standard guages you typically put in an "A" post guage pod? I was thinking Boost, Pyro & Transmition temp. Is this correct? I have a 2001 F-350 DRW 4x4with a 7.3 with an automatic and stock wheels and tires. The only mod done so far is an AFE air intake. I pull a 36' All American RV/Toyhauler loaded approx. 13,000 lbs loaded.Thanks in advance.
ADMIN/MAFIA
Boost, Pyro and Trans are by far a good investment for any diesel pickup. Im not sure if the 7.3 needs any specific gauges as the 6.0 does.
As stated above, the three basic gauges pretty much everyone puts in a triple pod are Boost, EGT, and Trans temp. These are the main things people like to watch. Since you tow, the trans temp and EGT are probably most important to you.
