ok guys here we go... dad has a 01 7.3 SD with 4" exhaust, K+N drop in, superchip gold, just had a cps sensor put in it by ford because he didnt call me first :damnit but he had no choice stranded... well about 3-4 weeks ago the truck has been starting very hard.. he just put a fuel pump on it today.. not sure if it was bad or if it was shotgunning part.. didnt get a full story. the things been starting really hard sometimes.. and when he lets it idle it will now and then start running rough "like it has a cam" he said. i told him to change the oil it is due, and hes due for a fuel filter change... what else could it be??? valve cover harness?? hes a mechanic by trade but hes a big diesel mechanical type diesel mechanic.. hes not to up on the powerstroke so... can yall help me out? could the chip be possibly going bad? its about 2-3 years old... been in it since about 3 days after he bought the truck :thanks: :thanks:
I would guess (without pulling codes) that the under valve cover harness is going bad on one side or the other... Or its just loose. Tell him to quit throwing parts at it and pull codes!!!
for hard starts first and formost is checking Glow plug system and fuel pressure while starting .. small elaks in the system can cause leak down when sitting making it hard starting.
same can hold true for the high pressure oil system if it leaks down it will crank to build pressure then fire and a leak of significant size can cause rough running on both systems fuel and oil
valve cover harness and wiring are prone for loose connections underneath the valve cover a clip kit has been made to help lock them in solid to prevent this and can cause both hard starting and rough running until it falls off completley then you get a no start .
another issue with valve cover wiring is if a glow plug shorts out it can melt down the harness and this can cause loss of glow plugs and hard start as well as a short to injector circuits causing rough running.
hes got no way to pull codes short of going to the dealer and paying them to do it for him.. ill see if i know anyone that can pull the codes for him to see... hes gunna change the oil and fuel filter tomorrow and ill tell him to check the harnesses... how can he check the harnesses short of pulling the covers?
Hell isnt Jeremy there? Have him run over there?
oh shoot darn good idea joe never thought about that! ill give jeremy a ringaling tomorrow he can prolly run over on saturday SWEET good call joe
