$99.99 FREE Shipping
New Product Introduction:
The ONLY Headlight Relay Harnesses that are SMART enough to carry the "BRITE
BOX" name!
Innova Design & Distributing, Inc., makers of the BRITE BOX, has introduced the
world's ONLY line of SMART Headlight Relay Harnesses that are fully compatible
with factory daytime running light (DRL) systems used in the USA and Canada!
"Dumb" harnesses cause you to violate the law because they require you to
disable your DRL's or have them run at full intensity.
Our SMART harnesses have our custom CONTROL MODULE that recognizes when the
vehicle has DRL on and allows the DRL signals to the headlights to be retained.
When you turn on your full intensity headlights, the CONTROL MODULE lets the
harness function like all others - which is to connect the headlight bulbs to
FULL BATTERY VOLTAGE for MAXIMUM BRIGHTNESS!
Our harnesses are MADE IN THE USA!
BRITE BOX SMART HARNESS HIGHLIGHTS:
• 100% Plug and Play Installation.
• 14 Gauge Headlight Wires.
• Our wire is USA made. Don't settle for import wire! Import wire typically has
extra thick insulation that makes the copper "under gauge"! Additionally, we
have seen import wire with poor quality copper.
• 30 / 40 Amp Relays.
• Control Module is fully encapsulated for waterproofing and vibration
resistance.
• Wires are encased in split loom tubing for protection.
• Fuse Protected, Water resistant fuse holders.
Note: Brite Box Smart Harnesses are application specific. Please check with your
dealer if unsure about correct harness for your vehicle!
Current Applications:
FORD F150 with Daytime Running Lights
1999 - 2003 - Brite Box Smart Harness Model H7.R1.9
2004 - 2008 - Brite Box Smart Harness Model H8.R1.9
FORD F250 SUPER DUTY with Daytime Running Lights
1999 - 2004 - Brite Box Smart Harness Model H7.R1.9
2005 - 2007 - Brite Box Smart Harness Model H8.R1.9
FORD F350 SUPER DUTY with Daytime Running Lights
FORD F450 SUPER DUTY with Daytime Running Lights
FORD F550 SUPER DUTY with Daytime Running Lights
TOYOTA 4RUNNER with Daytime Running Lights
1992 - 2002 - Brite Box Smart Harness Model HH4.R1.6
TOYOTA FJ CRUISER with Daytime Running Lights
2007 - 2010 - Brite Box Smart Harness Model HH4.R1.6
TOYOTA "PICKUP" with Daytime Running Lights
Note: After 1995, Toyota "Pickup" was called "Tacoma" - see below
1992 - 1995 - Brite Box Smart Harness Model HH4.R1.6
TOYOTA SEQUOIA with Daytime Running Lights
2001 - 2007 - Brite Box Smart Harness Model HH4.R1.6
TOYOTA TACOMA with Daytime Running Lights
Note: Before 1995, Toyota's "Pickup" was simply called "Pickup" - see above
1995 - 2004 - Brite Box Smart Harness Model HH4.R1.6
TOYOTA TUNDRA with Daytime Running Lights
2000 - 2006 - Brite Box Smart Harness Model HH4.R1.6
BOX" name!
resistance.
