I like Pretty Girls!
correct me if I am wrong but the job 2 and 3's have heat in the bottom part of the mirrors??
So my question is has anyone modiffied their Job 1's to have this? its a PIA backing up with frost on them so if its easy/cheap I would like to do this one day
It should be as easy as updating to a mirror assy, from a 2009 or later used truck or new part. I have not taken a mirror apart that has the heated lower mirror glass, but i'm pretty sure that the lower mirror is wired in series with the upper mirror. If you can find just the heated lower mirror glass, you should be able to splice into your upper wire for the heat.
just my .02
randy
From the 2009 Order Guide 12/01/08
PACKAGES/OPTIONS CHANGED
Exterior
• Stowable Bed Extender is no longer available on XL.
• Lower Accent Two-Tone Paint is no longer available on XLT.
• 18" Bright Machined Cast Aluminum w/Bright Hub Covers/Center
Ornaments available on XLT
• The Manual Telescoping Trailer Tow Mirrors w/Power Heated
Glass and the PowerScope™ Trailer Tow Mirrors now include
heated spotter mirrors
From the 2010 Order Guide
Mirrors
Manual Telescoping Trailer Tow Mirrors w/ Manual Glass ●
Manual Telescoping Trailer Tow Mirrors w/ Power Heated Glass and Heated Spotter
Mirror ●
PowerScope™ Trailer Tow Mirrors – Power Heated Glass / Power Telescoping / Power
Fold-away / Heated Spotter Mirror
From the 2011 Order Guide.............
Mirrors
Manual Telescoping Trailer Tow Mirrors w/Manual Glass ●
Manual Telescoping Trailer Tow Mirrors w/Power Heated Glass and Heated
Spotter Mirror ●
PowerScope™ Trailer Tow Mirrors – Power Heated Glass/ Power Telescoping/
Power Fold-away/ Heated Spotter Mirror/ integrated clearance lights/ turn
signals
Power Fold-away/ Heated Spotter Mirror/ Memory/ integrated clearance lights/
turn signals/ color keyed skull cap
Speed Junkie
My 08 Job 2 doesn't have heat lower mirrors either.
I never knew my Job 2 '09 had them until I read this thread, I checked, they are heated.:woot:
Mafia member #6
I also wondered why Ford didnt notice heating the bottom mirror would help alot in the testing that was done...
not that I have them apart but I was thinking that a guy could pop them apart then put in a heat strip... But probably just easier to buy the heated bottom mirror like Randy said
