on my truck the overflow keeps filling all the way up with antifreeze u can hear it bubbling in the passanger side dash that would be the heater core right?? i need to get it fixed asap thanks 4 any input...
2nd Gen Guru
Hmmm...
Any other material in the coolant?
Now is this occuring cold after you start the engine?
Could be as simple as a bad radiator cap...
i pressure tested the raditor cap and it dosent hold 15 psi at all it drops to about 12 psi thats not good right?? could be the cause??
2nd Gen Guru
Its a cheap start to finding the problem... I would replace it... It must hold the rated pressure for at least a few mintues...
it seems all godd since the new cap thanks moparman
2nd Gen Guru
Thats what I'm here for to help you guys out the best I can...:Thumbup:
have u seen this happen b4??
2nd Gen Guru
I've seen a lot of weird things...
But normal a good coolant flush and fill with a fresh cap and t-stat fixs most all that is wrong with a coolant system...
If done right it could be like mine. I've got 90K miles and 4 years on at the time of thes pics!
Looky NO RUST in the block!
No scale or lime build up on the radiator... Using standard tap water too...
