OASIS RESULT:
1FTNX21F31EA64165
See bottom of the OASIS result for contact ID
02/02/2006
09:50:16
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2001 F-SERIES BODY STYLE
F-250 SUPER CAB 4X4 ENGINE
7.3L TURBO - DI
TRANSMISSION
4R100 4SP (DIESEL) AXLE CODE
ENGINE CALIBRATION
1F719S0A
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
10/19/2000 BUILD DATE
09/24/2000 SALE MILEAGE
00010
ARN MESSAGES
BEFORE REPLACING DIESEL HIGH PRESSURE PUMP (-9A543-) SEE TSB 04-04-04
BEFORE REPLACING 7.3L DIESEL TURBO PEDESTALS (-6N639-) SEE TSB 04-20-02
CUDL MESSAGES
THIS VEHICLE HAS A CLOSED CUDL CONTACT
WARNING MESSAGES
LESS THAN TWO DEALER APPROVED AWA REPAIR VISITS PAID TO DATE
VERIFY VIN/WARRANTY COVERAGE
VEHICLE SOLD IN CANADA
SERVICE INFO MAY BE UNAVAILABLE
NO CAMPAIGN MESSAGE(S) FOUND
EXTENDED COVERAGES
NO ESP INFORMATION AVAILABLE
REPAIR HISTORY
08/06/2005
DEALER: Dan Pilson Auto Center, Inc.
WARRANTY CLAIM NUMBER: 016970 ODOMETER: 053754M
LABOR OP
CONDITION CODE
CONDITION DESC
YC3Z 2V120CARM CALIPER ASY FRONT BR 001 2001B7F 42 DOES NOT OPERATE PROPERLY
REPLACE STICKING CALIPER
1FTNX21F31EA64165 T/F7 T/F T/BD T/BD T/E A1 T/D8 T/DS 24-SEP-2000 19-OCT-2000 4B2546 CAN 4 7S22 1801XX * 14526 * L26 46 2672
AWS Claim Key: 621992 Trx Code: 2 Labor Hrs: 0.2
Dlr Cd-Sub Cd: 04640 - * Name: DAN PILSON AUTO CENTER, INC. Ph: 217-2346461 St:IL Ctry Cd: USA Reg Cd: NA Repr Date:24-JAN-2001 Doc #:052111A
Cust Comments: FOG LIGHTS DONT WORK
Tech Comments: VERIFY CONCERN AND CK FOR POWER AT LIGHT NONE PRESENT CK FUSE FUSE 12 UNDERHOOD, POWER DIST CENTER MISSING FUSE 10 UNDERHOOD POWER DISTRIBUTION CENTER AND CK WIRING AT C237 FOUND SHORT TO GROUND REMOVE PANEL ANDN REPAIR SHORT
1FTNX21F31EA64165 T/F7 T/F T/BD T/BD T/E A1 T/D8 T/DS 24-SEP-2000 19-OCT-2000 4B2546 CAN 4 7W01 180401 * 15052 * A87 30 2672
AWS Claim Key: 621993 Trx Code: 2 Labor Hrs: 0.4
Dlr Cd-Sub Cd: 04640 - * Name: DAN PILSON AUTO CENTER, INC. Ph: 217-2346461 St:IL Ctry Cd: USA Reg Cd: NA Repr Date:24-JAN-2001 Doc #:052111B
Cust Comments: CUSTOMER STATES THAT SPOT FOR CIG (POWER POINT) DOESNT WORK
Tech Comments: CK FUSES AND FOUND FUSE 10 IN UNDERHOOD PWER DISTRIBUTION CENTER OPEN CK WIRING AT C237 FOUDN SHORT TO GROUND REMOVE PANEL TO GAIN ACCESS AND REPAIR SHORT AND RETEST ALL OK
1FTNX21F31EA64165 T/F7 T/F T/BD T/BD T/E A1 T/D8 T/DS 24-SEP-2000 19-OCT-2000 4B2546 CAN 4 6C06 010504 YC3Z 2504104 BAB T90 01 2987
AWS Claim Key: 774135 Trx Code: 2 Labor Hrs: 0.5
Dlr Cd-Sub Cd: 04640 - * Name: DAN PILSON AUTO CENTER, INC. Ph: 217-2346461 St:IL Ctry Cd: USA Reg Cd: NA Repr Date:06-FEB-2001 Doc #:052541A
Cust Comments: INSTALL RT VISOR ON MIRROR SOP TECH #48
Tech Comments: REPLACE RIGHT SIDE VISOR MIRROR LOOKS LIKE FALLING OUT
1FTNX21F31EA64165 T/F7 T/F T/BD T/BD T/E A1 T/D8 T/DS 24-SEP-2000 19-OCT-2000 4B2546 CAN 6 7T09 191001 F81Z 14B205 EE A85 42 4768
AWS Claim Key: 1410654 Trx Code: 2 Labor Hrs: 5.6
Dlr Cd-Sub Cd: 04640 - * Name: DAN PILSON AUTO CENTER, INC. Ph: 217-2346461 St:IL Ctry Cd: USA Reg Cd: NA Repr Date:29-MAR-2001 Doc #:054247A
Cust Comments: CUSTOMER STATES KEYLESS ENTRY DOES NOT LOCK OR UNLOCK DOORS LIGHTS FLASH AND HORN HONK BUT LOCKS IN
Tech Comments: RUN CODES AND TRY TO REPROGRAM REMOTEST GEM NOT RESPONDING, TRY NGS ON GEM NO RESPONSE REPLACE FEN AND NOW WIPERS RUN ALL THE TIME INSTALL OLD GEM ANDSAVE CONFIG TO NGS SHOWS ERROR WONT REPROGRAM CAL L HOTLINE INSTRUCTED TO CALL CENTRAL ORDER PROCESSING TO GET CORRECT PART NUMBER INSTALL GEM THAT HOTLINE SAYS NEEDS NOW WIPERS OK DOOR LOCKS INOP TRYAND REPROGRAM AND TRACE WIRES
1FTNX21F31EA64165 T/F7 T/F T/BD T/BD T/E A1 T/D8 T/DS 24-SEP-2000 19-OCT-2000 4B2546 CAN 7 6R09 012005 YC3Z 14B321 CA S39 28 5375
AWS Claim Key: 1482399 Trx Code: 2 Labor Hrs: 7.5
Dlr Cd-Sub Cd: 08132 - * Name: RIDINGS-XAMIS OF SHELBYVILLE Ph: 217-7742191 St:IL Ctry Cd: USA Reg Cd: NA Repr Date:24-APR-2001 Doc #:04684701
Cust Comments: AIR BAG LIGHT IS ON
Tech Comments: DIAG FOR AIRBAG LIGHT FOUND CODE B1884 REPLACED SWITCH AND MODULE RETESTED LIGHT STILL ON CALL TECH LINE TRACED WIRING REPAIRED OKAY
1FTNX21F31EA64165 T/F7 T/F T/BD T/BD T/E A1 T/D8 T/DS 24-SEP-2000 19-OCT-2000 4B2546 CAN 17 7F03 011601 2C3Z 17508 BA W05 28 20829
AWS Claim Key: 7321341 Trx Code: E83 Labor Hrs: 1.4
Dlr Cd-Sub Cd: 08132 - * Name: RIDINGS-XAMIS OF SHELBYVILLE Ph: 217-7742191 St:IL Ctry Cd: USA Reg Cd: NA Repr Date:26-FEB-2002 Doc #:05154501
Cust Comments: FRONT WIPERS ARE INOP
Tech Comments: DIAG AND FOUND WIPER MOTOR BAD REPLACED ASSY RECHECKED OKAY
1FTNX21F31EA64165 T/F7 T/F T/BD T/BD T/E A1 T/D8 T/DS 24-SEP-2000 19-OCT-2000 4B2546 CAN 30 5B04 050306 1C3Z 3B396 CB P31 69 33306
AWS Claim Key: 13576722 Trx Code: E84 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 08132 - * Name: RIDINGS-XAMIS OF SHELBYVILLE Ph: 217-7742191 St:IL Ctry Cd: USA Reg Cd: NA Repr Date:24-MAR-2003 Doc #:05753501
Cust Comments: CUSTOMER STATES LOCK OUT HUBS IS VERY HARD TO LOCK IN
Tech Comments: DIAG FOUND BOTH LOCKING HUBS DEF. REPLACED RECHECKED OKAY
1FTNX21F31EA64165 T/F7 T/F T/BD T/BD T/E A1 T/D8 T/DS 24-SEP-2000 19-OCT-2000 4B2546 CAN 30 6R01 012000 * 16611A73 * S25 42 33306
AWS Claim Key: 13576723 Trx Code: E84 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 08132 - * Name: RIDINGS-XAMIS OF SHELBYVILLE Ph: 217-7742191 St:IL Ctry Cd: USA Reg Cd: NA Repr Date:24-MAR-2003 Doc #:05753502
Cust Comments: LEFT FRONT SEAT BELT WON'T BUCKEL PROPERLY
Tech Comments: DIAG FOUNF RETRACTOR STICKING REMOVED AND CLEANED AND ADJUSTED RECHECKED OKAY
1FTNX21F31EA64165 T/F7 T/F T/BD T/BD T/E A1 T/D8 T/DS 24-SEP-2000 19-OCT-2000 4B2546 CAN 51 2I04 NANANA F81Z 12B533 AC D03 42 50655
AWS Claim Key: 19279224 Trx Code: E72 Labor Hrs: 1.2
Dlr Cd-Sub Cd: 08132 - * Name: RIDINGS-XAMIS OF SHELBYVILLE Ph: 217-7742191 St:IL Ctry Cd: USA Reg Cd: NA Repr Date:29-NOV-2004 Doc #:0666291
Cust Comments: CUSTOMER STATES HARD TO START IST THING AND WHEN COLD
Tech Comments: DIAG FOUND GLO PLUG RELAY BAD REPLACED RECHECKD OKAY
1FTNX21F31EA64165 T/F7 T/F T/BD T/BD T/E A1 T/D8 T/DS 24-SEP-2000 19-OCT-2000 4B2546 CAN 59 5V03 060302 YC3Z 2V120 CARM H02 42 53754
AWS Claim Key: 20327833 Trx Code: SPW Labor Hrs: 0.6
Dlr Cd-Sub Cd: 04640 - * Name: DAN PILSON AUTO CENTER, INC. Ph: 217-2346461 St:IL Ctry Cd: USA Reg Cd: NA Repr Date:06-AUG-2005 Doc #:016970A
Cust Comments: RIGHT FRONT CALIPER IS STICKING PARTS WARRANTY
Tech Comments: REPLACE STICKING CALIPER
