1 - 19 of 19 Posts
*^%$#@&am p;am p;am p;am p;am
has 190,000miles on clock
my trucks engine is starting to stutter
its like its shutsdown for a second or two then goes fine
the first time it happen i had a dead pedal for about 30 seconds
any ideas?
if it is the cps who sells the best one?
That does sound like the cam position sensor. Go to the dealer and get it. They are now only about $35 I think. I have not had much success with them from other auto parts stores. Takes about 10 minutes to replace.
they cost $500 from the dealer here in australia
maybe one of the sponsers sells them on here
$500!!!!!!!!:eek:
dave if you cant find a sponsor that sells them I will pick you up one and ship it to you
Reactions: AUSSIEDAVE
better yet buy 2. shipping wont cost any more and it would be a good idea to get a spare.
MAFIA MEMBER 106
hey dave any codes? it sounds like a uvch harness to me but if ya need a cam sensor id be glad to buy one and ship it to you
MAFIA MEMBER 106
ha ha ross ya beat me lol
dont have a code reader
whats a uvch harness?
and what cauces the harness to fail?
the uvc harness is the harnesses that connect from the valve cover gasket to the injectors under the valve cover. the glow plug wires go through there too and over time sometimes they will melt due to bad connections and the large amount of current that goes through there to the glow plugs.
dose the engine die or dose it go to idle when it cutts out. if it just goes to idle it could be your throttle position sensor too
MAFIA MEMBER 106
dave UVCH under valve cover harness. Under the valve covers where the wires go into it on the inside when mine got loose it would drop a cyl then fire again pull the v/c and look at the connection to see if its in tight if it is then youll need a cps
MAFIA MEMBER 106
argh ross got me again
too slow:haha
Discussion Starter #13
not sure as it has only just started happening
my truck is also a manual
i think the first time it happened it went back to idle
can i get a thottle sensor from the vendors as well?
Reactions: camojeeper
MAFIA MEMBER 106
dave does it do it in cruse?
Discussion Starter #15
MAFIA MEMBER 106
ya I ment cruse control if it happens under accl i would say cps
Discussion Starter #17
i need a couple of cps units
could you help me get them overhere?
MAFIA MEMBER 106
you bet dave ill pick em up and get you an email not sure if i still have your addy overthere ill have them by monday
steve
1 - 19 of 19 Posts
