1 - 10 of 10 Posts
Diesel Addict
What can i do to reset the pcm n ecm in my truck the efi stoped early in the loading proceedure n wont do nothing now other than say bootloader failed to connect to pcm.....fml
CRAZY CANUCK
I know its a dumb question, but was your key turned all the way forward? I know the first few times I tried to load a tune it wouldnt load because i had the key on, but not all the way forward...
Does the truck still run? I am pretty sure that there is a safety built into EFI that will return it to stock if the new tune doesnt load
Pardue the Traveler
Do you have the stock tune? You may have to re-flash the stock tune in, then try flashing the new tune.
Diesel Addict
thanks but it wouldnt read the ecm...at all...ive used efi a few times i just did something i shouldnt have n now i have a new ecm because of it....lol
CRAZY CANUCK
What did you do exactly? so I know what to avoid, thanks in advance :happymugs
Diesel Addict
I just had my computer replaced in my truck due to an efi live screw up...ill take the blam:notme....truck works n runs fine stock...when i went to install a new tune on it says either bootloader rejected ecm returned to normal try again, or it says cant read ecm...it wont tune the engine or the transmission...i get the say responses...:read
CRAZY CANUCK
Efi was locked to your old ecm, each ecm carries a different serial # and efi locks to that number, you may have to use your second lisence on the new ecm
Diesel Addict
i got a new license n locked to new ecm...still wont work
CRAZY CANUCK
Time to call efi customer support, or post your question at www.efilive.com forum, them guys will know what to do
Diesel Addict
i was in a hurry originally and just started to tun the truck n realized i forgot to chang somethin...tire size n rev limiter....so i stoped the upload into the truck...knowin better that i shouldnt....then it left the computer unrecoverable....wont do that again...but now my new comp wont take the tune i can read the comp but it wont upload...
1 - 10 of 10 Posts
