Rockin the Bakken
I went to replace the front wheel bearing in my 2004 F250 4X4 and as soon as i got the HUB BEARING ASSEMBLY off i realized the spline shaft the hub is attached to moves around pretrty freely what do i do now?????? Please any advise, its up on blocks now and i need it for work so please any help at all
Old Fart
The hubs on the 2004 do more pretty freely, on the spline. Unless you see ware on the splined shaft or the hub don't get too worried about it. If you are freaked out about it, then it maybe time to change to Warn hubs. I run the factory hubs.
Rockin the Bakken
Discussion Starter · #3 ·
ok thanks. I guess i was just so used to to old style warn hubs i thought i was screwed but thanks for the advise
