How in the heck are you guys running new wire through your doors for components or any speaker at that??? I found out the hard way that it has a din plug on it vs the old loom through the door on the new ones. The only way I see of doing it differently is to cut the oem wire and run wires from the stock deck back to the amp. Im not going to do that
cut the wire and put the new end on it :thumbsup:
the question I have is, like on a component set, you have the tweeter and the midrange. my thoughts were to stick the tweeter on the top of the pillar in the corner. I suppose you cant do that on this setup since the crossover has to be mounted on or inside the door pannel right?
