Super *********
I was working on my truck. 08 SuperDuty with the DPF delete and fully Spartan'd when I leaned over the hood with remote in packet and triggered the alarm.
Now both keys flash security and will not crank over the engine. Dashdaq dies fit recognize the computer. Just says no vehicle found then doing a scan. Also it seemed to erase all tunes as when I go to load tunes there are none on the card. I'm testing the sd in a computer this am and will update what is on card
Thx
try this
Re-initialize Ford System 3 (or 4) Alarm System:
Disconnect the battery. Wait 2 minutes for the module to lose all traces of voltage.
Turn the ignition key to the RUN position.
Reconnect the battery.
Shut the key OFF and press LOCK on the drivers door switch.
It's called reinitializing the alarm.
