hi i am new to this forum and it is because my truck would cut out under hard acceleration and the it just died under normal acceleration. my truck is a 2001 5.9 with banks big hoss tuner, 4" banks exhaust with power elbow and a K&N air filtert. the engine light is on and the error code is P1693 i looked it up but that didnt tell me how to fix the problem i just changed the fuel filter if that helps anybody. any help would be appreciated thanks
will it start again? if it starts will it run?
Well we need all the codes you going to need to use a scanner... The error codes are going to give us a answer...
http://mopar.mopar1973man.com/2002%20Dodge/Tips%20&%20Tricks/error%20codes/error_codes.htm
How was you fuel pressure? Hopefully about 10 PSI...
http://mopar.mopar1973man.com/2002%20Dodge/Tips%20&%20Tricks/lift%20pump/lift%20pump.htm
But you might try to re-prime the system...
http://mopar.mopar1973man.com/2002%20Dodge/Tips%20&%20Tricks/prime%20fuel%20system/prime%20fuel%20system.htm
no the truck does not run it doesnt even fire i am going out of town in the morning but i will reprime the fuelk system again to make sure all the air is out, i dont have scanner so i think i will end up having to take it in huh. well thanks for all your help
go to Autozone its a $200 deposit to rent a scanner, but you get it back when you take it back, if they tell you they don't loan them, inform them that they do (at least that's what I used to have to do at the ones here).
hey man did u figure it out my truck hase done the same thing do u have fuel at the head if u get it i need all the help i can get right now
